Why doesn't Hurst make a 4spd knob w/ a button??
Old Mar 20, 2007 | 11:54 AM
Corey_68's Avatar
Corey_68
Default Why doesn't Hurst make a 4spd **** w/ a button??
I need a new **** since install my line-lock but Hurst only has them in 5-6speed.
Old Mar 20, 2007 | 01:06 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I bought a T handle with a button for mine. Check E-bay.
Old Mar 20, 2007 | 01:18 PM
rihwoods's Avatar
rihwoods
Drill a hole in the 4 speed ****...install switch...
bashcraft's Avatar
bashcraft
This is what I use.
http://www.jegs.com/webapp/wcs/store...60641_-1_10159
Old Mar 20, 2007 | 01:26 PM
big_G's Avatar
big_G
I modified my T-handle to look/work like this one...
Old Mar 20, 2007 | 02:29 PM
63mako's Avatar
63mako
That is what I got.
Old Mar 20, 2007 | 02:45 PM
88turboGT's Avatar
88turboGT
So take some white finger nail polish and paint the 5 gear out …… no big deal…
Old Mar 20, 2007 | 06:17 PM
markdtn's Avatar
markdtn
I thought they used to? Pretty sure I remember them from the 80s.
Old Mar 20, 2007 | 07:13 PM
oregonsharkman's Avatar
oregonsharkman
All good except reverse is in the wrong spot You must have an automatic in your vette
Old Mar 20, 2007 | 11:15 PM
Corey_68's Avatar
Corey_68
Well I had a T-handle and hated it, so that's not an option.
Old Mar 20, 2007 | 11:50 PM
chris73cpe's Avatar
chris73cpe
you could just take off all the numbers.. isn't the shift pattern on the console anyway?
Old Mar 21, 2007 | 12:01 AM
redvetracr's Avatar
redvetracr
or you could e-mail or telephone Hurst....
Old Mar 21, 2007 | 12:45 AM
Secret Squirrel's Avatar
Secret Squirrel
Why not get a Black one with Hurst insignia on it...........you know where the gears are.........don't 'ya
Old Mar 21, 2007 | 01:13 PM
88turboGT's Avatar
88turboGT
Your right.... my bad.... If you have to look at your shifter **** to know where your gears are at...it could be a snag.....
Who says sticks are just for hillbillies....
Old Mar 21, 2007 | 01:56 PM
Corey_68's Avatar
Corey_68
You mean they'll make a one off just for me????
Old Mar 21, 2007 | 01:58 PM
Corey_68's Avatar
Corey_68
That's probably what I will do.
Old Mar 21, 2007 | 01:59 PM
bashcraft's Avatar
bashcraft
I'm sure they will. How much money you got?
To Why doesn't Hurst make a 4spd knob w/ a button??
Old Mar 21, 2007 | 02:07 PM
Corey_68's Avatar
Corey_68
Even if I had it it's not worth it.
Old Mar 21, 2007 | 05:46 PM
toddalin's Avatar
toddalin
As noted, in the past, they did make a 4-speed ball with a button, and the reverse in the proper location.
Actually, all of the new shift ***** are made pretty cheaply compared to the old *****. I have an old Hurst 4-speed ball on my '64 and the color is a creamier shade of white. But more importantly, the shift pattern is engraved into the ball and colored in, whereas the new ones are simply stamped on the surface.
Old Mar 21, 2007 | 07:49 PM
bondoboy's Avatar
bondoboy
I bought my shifter last year and the shift pattern is engraved into the ****.
