Power Steering Rebuild
Old Mar 20, 2007 | 12:17 PM
rjken1969's Avatar
rjken1969
Default Power Steering Rebuild
I've seen that VB&P sells a rebuild system for under $300. This includes a valve, cylinder, (4) hoses, and ps fluid. I was thinking of getting this system. I'm assuming there using rebuilt parts based on the pricing.
Does anyone have any experience with these kits? How difficult would this be to install in a driveway with the car on ramps, using hand tools? Are there special tools or adjustments required?
Old Mar 20, 2007 | 02:57 PM
Tom454's Avatar
Tom454
General experience with rebuilt valves is that they are worn out beyond use and it takes 2 or 3 before you get one that doesn't leak.... at least for a few months.
Pay yer money, take yer chances.
The parts that wear the most (re-used) are not available separately.... the housing half and the internal sliding sleeve.
Old Mar 20, 2007 | 10:01 PM
stock76's Avatar
stock76
The VBP control valve and power steering cylinder in the kit are rebuilt units. As with any "rebuilt" part, you can get a bad one. I installed their kit and it appears the control valve from my kit is bad and I'm going to have to replace it.
My advice would be to buy new, not rebuilt. VBP also offers brand new valves and cylinders. The price difference is well worth the aggravation and time you will save if you have to do it over. Lot less likely to get a defective one if you buy a new unit.
If budget is a problem you might consider rebuilding the valve yourself if the internals look ok. Rebuild kits are not expensive, but if your valve looks is shot, then I would just bite the bullet and buy a new one.
There are a couple of special tools you need - a ball joint separator to get the control valve off and maybe a pickle fork for the other stuff. Do a thread search. There is a lot of excellent info on this forum on power steering. Good luck.
To Power Steering Rebuild
