Front Driveshaft removal from Differential
Old Mar 20, 2007 | 04:41 PM
tomard's Avatar
tomard
Default Front Driveshaft removal from Differential
Can someone tell me HOW to remove the driveshaft FROM the differential on an 80' ? I have the shop manual but I am not clear on what it is telling me .... I cannot remove the center bolt as I cannot get behind to hold onto the bolt to remove the nut & the driveshaft is still connected so there is not much room.
I have everything else OFF, except for X-member & driveshaft and the FRONT bolt that holds DIFF to center frame cross.
Taking out the differential so that I can have 3 broken leaf spring mounting plate bolts drilled out and removed AND a drain plug installed.
Old Mar 20, 2007 | 04:44 PM
SIXFOOTER's Avatar
SIXFOOTER
I took the bolts off the straps on the U-Joints front and rear, Use a 1/4" 12pt socket and a 1/4" drive ratchet, might need an extension
Old Mar 20, 2007 | 05:12 PM
dannyman's Avatar
dannyman
Transmission in neutral and rear wheels off the ground?
You should be able to rotate the driveshaft by spinning wheel, to a spot where you have easier access.
Old Mar 20, 2007 | 06:15 PM
tomard's Avatar
tomard
Default Did you remove entire driveshaft then?
So you disconnected it both in the Tranny and at the differential?
Old Mar 20, 2007 | 06:16 PM
tomard's Avatar
tomard
The wheel shafts are already off the wheel ......
Old Mar 20, 2007 | 06:17 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Yes.
I did the tranny first. Makes rotating the differential easier.
Old Mar 20, 2007 | 10:49 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
i'm not clear on what you're asking.
are you removing the drive shaft from the differential yoke?
or are you removing the front bolt on the differential tongue?
Old Mar 21, 2007 | 01:31 PM
a1sensei's Avatar
a1sensei
I think this is what everyone is saying, but having just done it last week, let me try to make things clearer. Unbolt it from the tranny first so you can move it around. Get a 1/4" 12 point socket (got mine at Sears), a ratchet and two long extensions. Reach back down the tunnel and you should be able to unbolt it from the yoke. God bless, Sensei
Old Mar 21, 2007 | 02:28 PM
tomard's Avatar
tomard
I will do exactly that either LATE tonight when I get home or tomorrow .... Thanks much ....
P.S - do you have your HEAT SHIELD that screws into the strut assembly under the spring? I need to get a template so I can have one made .....
At what point does the cover/crossmember open up, so I can drain the old fluid? I have all the bolts out but it seems tight??????
Old Mar 22, 2007 | 07:48 AM
tomard's Avatar
tomard
I am trying to remove it at the diff yoke - will try to remove shaft from tranny first and see if I have enough room to get in there that way.
Another question: why "mark" the shafts? They seem to be same size any which way ..... and unless one side is somehow heavier than other so that there would be a "balance" issue, I don't understand what that is all about ......
Old Mar 22, 2007 | 08:33 AM
aussiejohn's Avatar
aussiejohn
Default heavy duty cover
tomard,
Rather than re-drill your stripped holes, for about $70 (I think) you can get a heavy duty cast iron rear cover that should make it impossible for the threads to strip again. If I was going to all that trouble to pull the diff out, that's what I'd do.
Regards from Down Under
aussiejohn
Old Mar 22, 2007 | 09:38 AM
tomard's Avatar
tomard
What vendor would I get that from? The holes that I am talking about are the 3 bolts that hold the Leaf spring mounting plate (that holds spring up in place), that looks like it is part of x-member.
Is the rear diff cover and xmember 1 piece or 2 ???
To Front Driveshaft removal from Differential
