Turn Signal Blinks REALLY FAST
Old Mar 20, 2007 | 10:05 PM
VictoriaVette's Avatar
VictoriaVette
Default Turn Signal Blinks REALLY FAST
I noticed that my turn signals blink really fast is this normal? Or do I just need to change the flasher? link 2 to 3 times per sec.
Old Mar 20, 2007 | 10:07 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
do you have a bulb out?????
Old Mar 20, 2007 | 10:09 PM
randommj's Avatar
randommj
chech your blinker fliud, lol just kidding, what about not blinking at all, mine just tuns on and dosent blink
randommj
Old Mar 20, 2007 | 10:10 PM
Big2Bird's Avatar
Big2Bird
High flasher life denotes overload or worn out. Adding load, ie trailer lts, increases the rate of flash.
Old Mar 20, 2007 | 10:20 PM
VictoriaVette
Blinker Fluid was the first thing I checked a little low but topped it off, NO Change! LOL I did not check my bulbs I was thinking if a bulb was out it would not blink on that side. There I go thinking again!! What would I do with out so many REALLY SMART people like you all!!!
Old Mar 20, 2007 | 10:21 PM
Vette80regon's Avatar
Vette80regon
You've got a bad blinker bulb.
99.9% positive that's the reason why.
Old Mar 20, 2007 | 10:27 PM
Big2Bird's Avatar
Big2Bird
randommj
You have a lamp out.
Old Mar 20, 2007 | 10:29 PM
Big2Bird's Avatar
Big2Bird
As the current flows thru a flasher, it heats a bi-metallic strip. Lamp out=no load. No flash. High load=more current. Faster flash rate. Trailers require HD flashers. (More current flow)
Old Mar 20, 2007 | 11:05 PM
Glassbowtie77's Avatar
Glassbowtie77
I had the same problem with mine, thought it was a bulb also. It turned out to be the flasher was bad. I replaced it and everything became normal. The turn signal flasher is located behind the passenger side dash panel. The one for the emergency flashers is located in the fuse panel block. Both of mine were originals so I replaced them both, certainly cheap enough at 3 bucks apiece. Good luck
Old Mar 21, 2007 | 06:54 AM
Jim Shea's Avatar
Jim Shea
I found this over on the Camaro Tech board. It might have something with respect to your problem.
Although a quick flash normally does indicate that there is a bulb that is out.
Jim
Original equipment bulbs on most pre-'72 cars was as follows:
1034: dual-filament park/turn and brake tail. Clear bulb for use with red rear or amber front lens.
1034A or 1034NA: dual-filament park/turn. Amber bulb for use with clear front lens.
1141 or 1073: single-filament bulb. Reversing/backup lights (and single-function—brake-only, turn-only—lights frequently found on old Mopars).
In the early '70s, the 1034 was replaced by the 1157, the 1073/1141 by the 1156. These 1150-series bulbs put out the same amount of light, but draw slightly more current and last quite a bit longer. When changing from 1034s to 1157s, often it was (and is) necessary to replace the turn signal flasher, because the original would flash too fast if used with 1157s. Nowtimes, it's difficult to find a flasher calibrated for 1034s.
Old Mar 21, 2007 | 09:21 AM
75 Red Vert's Avatar
75 Red Vert
Thank you for that info. Mine blink really fast too. Off to Advance Auto Parts.
Old Mar 21, 2007 | 09:26 AM
kevinator80's Avatar
kevinator80
Not that you need any backup. but
kevinator80
Dead on again.
Old Mar 21, 2007 | 12:02 PM
randommj's Avatar
randommj
a light bulb?
Miles
Old Mar 21, 2007 | 12:10 PM
Big2Bird's Avatar
Big2Bird
a light bulb?
Miles
PM sent
To Turn Signal Blinks REALLY FAST
