offset rocker arms
Old Mar 21, 2007 | 06:40 PM
lvrpool32's Avatar
lvrpool32
Default offset rocker arms
I was looking at some new rocker arms and i see them advertised as being std, .100", .150" etc offset. What are the advantages/consequences of using an offset rocker arm?
Nick
Old Mar 21, 2007 | 06:49 PM
Gordonm's Avatar
Gordonm
They are required on some heads that have very large ports. In order to get the ports large enough they have to push the pushrods over slightly to clear the ports. The makes it needed to offset the rocker arms to maintain good geometry.
Old Mar 21, 2007 | 07:06 PM
gkull's Avatar
gkull
to be used with offset lifters. My dart heads have altered valve locations. They are spread wider and shifted called 60/40 to use bigger valve sizes
Old Mar 21, 2007 | 07:22 PM
lvrpool32's Avatar
lvrpool32
OK, so they wouldnt be used on a standard head.
thanx guys.
Nick
Old Mar 21, 2007 | 07:27 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Remember these used on the old Trick Flow Twisted wedge heads. Think they screwed up the valvetrain geometry and caused side loading of the valve guides and premature valvetrain failures. But they flowed good. Sounds like race only stuff to me.
Old Mar 21, 2007 | 08:10 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I have Trick Flow G1 twisted wedge heads with standard 1.6 aluminum rollers. Geometry is spot on.
The intake valves are 13* and careful pushrod selection is crucial...but no offset....
Old Mar 21, 2007 | 09:49 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
There are also *backset* rockers that help straighten out geometry issues. Real handy on AFR big block heads!!
JIM
Old Mar 21, 2007 | 10:28 PM
63mako's Avatar
63mako
It's only as good as the builder! I think they required special pistons with different reliefs but on a blower motor with dish pistons probably not an issue. I know they flow big numbers especially on the exhaust side. Probably work great on the blower motor if the valvetrain is set up right.
Old Mar 21, 2007 | 10:37 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Yeah, they won't work with domed 23* pistons. They were very resonably priced and I think got a bad rap. Some had guide problems but again I think due to screwed up geometry. I think I'll keep 'em
To offset rocker arms
