Help! What is a 2 piece block?
Old Mar 23, 2007 | 02:12 PM
pin_point527's Avatar
pin_point527
Default Help! What is a 2 piece block?
What is the difference between a one and two piece block? and how do i figure it out?
Old Mar 23, 2007 | 02:17 PM
big_G's Avatar
big_G
Generally, factory installed blocks after 1985 were 1-piece rear main seals. All prior blocks and some replacement/aftermarket blocks had 2 piece rear main seals. Different flywheels are required, as the crankshaft flange style is different.
Old Mar 23, 2007 | 02:20 PM
Gordonm's Avatar
Gordonm
Also they have provisions for the spyder that holds in the roller lifters.
To Help! What is a 2 piece block?
