Warning: Wood insert for console problems
Old Mar 24, 2007 | 02:33 PM
Spot Rot's Avatar
Spot Rot
Default Warning: Wood insert for console problems
FYI, Recently I've purchased 2 'wood' inserts for the console, one from Ecklers and one from Corvette World. Both suffered these problems:
A. Cut-outs were a little off so that the insert would not seat on the console plate. I used a dremel grinder to enlarge the slots.
B. The adhesive was weak. Neither would adhere to the plate for more than a few minutes. The console surface was very clean, no silicone or Armor-All. I've designed a number of parts that use an adhesive backing, and there are different levels of quality of adhesives. These must have a cheap, "non-aggressive" adhesive.
In past years, I've installed dozens of console inserts with no problems. Once, again, it's a shame when a 10 minute job takes hours due to poorly made replacement parts. I hope this helps or at least prepares other forum members for these problems.
John
Old Mar 24, 2007 | 03:41 PM
copter's Avatar
copter
Me too,Very unsatisfied.
Old Mar 24, 2007 | 03:49 PM
CCrane65's Avatar
CCrane65
John, I ran into the same problem with one I got from Corvette Central. I was able to work it over with a razor blade after carefully putting the backing paper back on.
I would bet that these were made from a copy which makes them slightly smaller than the template.
As far as the adhesive, I'm sure there is a compromise between epoxy and school paste. On the one hand, if they use a permanent glue or cement they risk ruining an expensive shifter plate. If the insert ever has to be replaced you're out of luck. But there is certainly better options that what they used that won't destroy the surface of the shifter plate.
I ended up getting mine to stick by going over my shifter plate with 90% rubbing alcohol before I ever tried it. The 70% alcohol leaves a residue that can make weak adhesives not stick. Then I sprayed the back with 3M Spray Adhesive. Applied correctly that stuff will hold most anything.
cc
Old Mar 25, 2007 | 11:32 AM
Spot Rot's Avatar
Spot Rot
cc,
Thanks for the adhesive suggestions. I have the same concerns about what they would be like to remove later.
I'll probably use 3M spray trim adhesive, but apply it to the plate with a small brush. I wonder how that gummy stuff some magazines use to attach sales flyers would work.
Correction: I recall now that I used a fine file to open the cut-outs, supporting the flimsy aluminum substrate in a soft-jawed vise.
John
Old Mar 25, 2007 | 11:02 PM
CCrane65's Avatar
CCrane65
Originally Posted by Spot Rot
cc,
John
You mean that stuff we always used as fake snot when we were kids? lol.
It holds well but it's pretty thick. I think you'd have a noticeable depth problem between the shifter plate and the insert.
The 3M adhesive worked really well. I'm curious, contact cement like 3M adhesive is very difficult to apply evenly with a brush why wouldn't you use the spray?
cc
Old Mar 25, 2007 | 11:07 PM
mkflanagan's Avatar
mkflanagan
Thanks for the warning,I was considering ordering one of these kits but I will reconsider now.
Old Mar 25, 2007 | 11:57 PM
SIXFOOTER's Avatar
SIXFOOTER
I have had two of those kits and they both dropped in perfectly. That was a whila ago, last one was 5 yrs, maybe they use a different supplier now.
Old Mar 26, 2007 | 09:28 AM
okinawa86vette's Avatar
okinawa86vette
I just got a console piece and the 2 door pieces from Mid America about 4 or 5 months ago. Everything fit perfectly and the adhesive stuck like, well, glue.
Chris
Old Mar 26, 2007 | 10:41 AM
Chris Farrer's Avatar
Chris Farrer
The one I got from Ecklers didn't fit well so I cleaned up the old one and put it back on.
Old Mar 26, 2007 | 01:14 PM
ShaneLU97's Avatar
ShaneLU97
Make your own...
http://forums.corvetteforum.com/show...post1559352767
Old Mar 26, 2007 | 01:22 PM
68 NJConv 454's Avatar
68 NJConv 454
Any pics, i got a nice oak woodgrain steering wheel and was considering a wood overlay for the consul or maybe a carbon fiber or aluminum. I'd like to see how the wood looked, any before and after pics??
Thanks for the warning.
Nevermind just saw them on your other post, amazing!!!!! just what i had pictured in my head.
Old Mar 26, 2007 | 06:06 PM
Spot Rot's Avatar
Spot Rot
Chris,
Thanks for the feedback, perhaps MidAmerica has a better supplier for this part.
I didn't use spray glue on the console plate because I am too lazy to tape everything.
Then it was too difficult to remove the poor adhesive from the back of the insert, so I just used 3M double sided tape. Holding good so far.
John
Old May 21, 2007 | 08:27 PM
Spot Rot's Avatar
Spot Rot
Default double-sided tape NG
Might save someone the effort: The tape only held for a little while.
I then pulled the plate, masked it, and sprayed with 3M General Trim Adhesive, 08088.
'Sprayed the backside of the insert too. I tried to remove the defective adhesive but that was not going to happen so I sprayed over it -- seems to be holding several weeks later.
It's frustrating that someone just sent an original insert to China and said "Copy this a cheaply as you can." -- and then the parts distributors dump it on us. The crappy quality made a 5 minute job take about 2 hours (with trimming, R&R, masking etc.)
It would be great if there was a resource to identify good vs bad reproduction Corvette parts.
To Warning: Wood insert for console problems
