Hooker side pipes and efi
Old Mar 24, 2007 | 08:38 PM
L82RedShark's Avatar
L82RedShark
Default Hooker side pipes and efi
I am wondering if anyone here has the hooker header side pipes mounted on an EFI sbc engine. If any one does ... just where did you install the O2 sensor?
Thanks,
David
Old Mar 24, 2007 | 08:47 PM
shafrs3's Avatar
shafrs3
I know one guy that put his outside about where the side vent is. Look carefully, you can see it in this photo, you'll probably need to zoom in. It's a really bad location to be effective.
Old Mar 24, 2007 | 09:02 PM
L82RedShark
Pictures are worth a thousand words, and that one shows what I don't want to have to do. I was hoping that there was a way to hide the O2 sensor. I don't think the distance will be to far for the wideband O2 I will be using, but if I can't hide it from view some how I will have to rethink my exhaust system. Which really sucks, because I truly love the look of those side pipes.
Old Mar 24, 2007 | 09:30 PM
shafrs3's Avatar
shafrs3
I don't think it can be done without drilling a big hole in the frame for the sensor.
If it's any consolation, side pipes don't flow for beans. Search for a recent thread about this very subject. Some engines, probably big blocks, took a 100hp hit.
Old Mar 24, 2007 | 10:01 PM
L82RedShark
Sounds like I will be rethinking my exhaust then. Thanks for the help. Now back to researching the forum and archives.
David
Old Mar 24, 2007 | 10:54 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Stock sidepies hurt HP. Patriot sidepipes also. Neither flow well. Hooker Super competition sidepipes Have 1 7/8 ports, equal length primaries and dump into a 4" tube. They flow just fine. The big HP loss would come from putting a reverse flow or glasspack insert in them. Put Max Flows or Turbo spiral baffles in them they are one of the best performance exhausts available.
Old Mar 24, 2007 | 11:22 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
I don't have a pic with me right now but I installed mine at the collector at about the 4 o'clock position (looking from the end of the collector), they just clear the frame, its not the best place for O2 sensor life but it works. I don,t have EFI, I use them for my O2 meters.
Neal
Old Mar 25, 2007 | 12:20 AM
L82RedShark
Thanks for the info Neal. I did some searching on jegs and found this little bit of info
Sidemount Headers
1963-82 Corvette SBC 265-400
1-7/8" Primary Tubes
4" Collector
High Temp Black Paint
520-2224
Hooker mufflers #520-21021 (glass pack) or #520-21002 (reverse flow design for maximum sound control)or #520-21046 Max Flow sidepipe muffler, slip-in design to be used with 4" sidetubes.
Installation requires #520-10922 for mounting alternator/generator on right side.
Will not fit angle plug heads.
Available with fitting to accommodate oxygen sensor.
Now to just figure out where hooker is putting the O2 at ..hmmm
Old Mar 25, 2007 | 12:39 AM
63mako's Avatar
63mako
The primary tubes on these are 1/8 inch smaller than the dual exhaust opening on a stock Base engine small block dual exhaust. You have 8 of these equal length. They flow just fine I have seen posts on EFI and hookers and also some have welded an O2 sensor bung into there hookers. I want a bolt in adaptor for my chrome hookers. If anyone has done this or knows where to get one or how to do it, chime in!!
Old Mar 25, 2007 | 07:32 PM
VetteNut72's Avatar
VetteNut72
Here is where I put mine.
I also run Performer angle plug heads with no clearance issues with my hookers.
Craig
Old Mar 25, 2007 | 08:22 PM
shafrs3's Avatar
shafrs3
The sensor is supposed to be at the 2:00 or 10:00 position minimum otherwise water can collect and ruin it, according to my Holley install manual. I have never seen a sensor on a factory car installed pointed downward, so there must be some truth to this.
L82RedShark
Thanks VetteNut72, those pics have shown me just which way to go with my exhaust system. Jegs is getting an order for the hookers in the very near future.
Old Mar 25, 2007 | 08:41 PM
L82RedShark
well I am just getting out of buick grand nationals and the factory location on those is roughly 5:00. So i am not so sure that there will be any issue with a 3:00 or 9:00 position. Just curious is your holley system use a wideband sensor?
Old Mar 25, 2007 | 08:58 PM
shafrs3's Avatar
shafrs3
Not originally, it does now.
Old Mar 26, 2007 | 05:47 AM
3X2's Avatar
3X2
Unless you have your heart set on Hookers, Stahl headers have the collector more or less under the framerail behind the tire. Far better made header than Hookers and make more power.
http://stahlheaders.com/Frame%20New%20RR.htm
The O2 should not be mounted in a way that it points upward due to water damaging it.
Mark
To Hooker side pipes and efi
