81 vette top rebuild
Old Mar 25, 2007 | 08:19 PM
81vettelover1's Avatar
81vettelover1
Default 81 vette top rebuild
Ok last year I had a rocker loosen up and raised heck with the head. So I have bought new heads ( RHS cast iron) new intake (cyclone) and going with roller rockers.already installed MSD distributor and non computer carb before this happened with the head. Now question is I found two lifters that were domed in just a small amount. Does this mean that I should replace the cam and lifters too? If so what cam should I put in it? I want to be able to feel it at idle. It is a stock 350 besides the new top end parts. Just streetable. Thanks Randy
Old Mar 25, 2007 | 10:51 PM
Big2Bird's Avatar
Big2Bird
I would. These motors are notorious for loosing lobe ht. I bet if you checked the cam with a dial indicator, those lobes are bad.
I believe the GM 151 cam is good for what you want/describe.
