Starter Shims (help)
Old Mar 25, 2007 | 08:55 PM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Default Starter Shims (help)
Screwed up this weekend when I realized I threw away the shims for my new MDS starter. I've sent an email to MSD to see if they can send a new set...but just in case, I'm trying to see if I can get these from a local auto parts store.
Can anyone help me figure out what the part number would be from Autozone or NAPA? Here is a shot of the starter I installed on my 1980 L48 manual.
Thanks...
Old Mar 25, 2007 | 08:59 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
just use stock chevy shims and all autoparts stores sould carry them....around here there is in aisle inthe pepboys that has universal replacement stuff....they have these shims in that area. did you check to see if you need them?
Old Mar 25, 2007 | 10:19 PM
80TexasC3's Avatar
80TexasC3
Thanks... I can't get into the gear/flywheel area to easily check the fit..but the symptoms are as though it is too tight... stock starter worked just fine. Installed MDS and now it turns over but then slows down and speeds up again as it turns over...also sounds like it is having some difficulty with disengaging.
Sound like I need a shimor two to you?
Old Mar 25, 2007 | 10:27 PM
bobs77vet's Avatar
bobs77vet
i don't think it can hurt anything to try
Old Mar 25, 2007 | 10:37 PM
80TexasC3's Avatar
80TexasC3
Thanks Bob... Since these are easy to install/remove...I'll try one at a time and halt as soon as it frees up (that is, if it works).
Old Mar 25, 2007 | 10:53 PM
Big2Bird's Avatar
Big2Bird
Yep. Can you stick in a wire gauge with the bendix engaged, flywheel cover off?
Old Mar 26, 2007 | 09:43 AM
80TexasC3's Avatar
80TexasC3
Can definitely get a wire gage in but could not get the bendix engaged to test. Thus, reasoning for inserting a shim and increasing until binding is relieved.
Old Mar 26, 2007 | 11:43 AM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
This sounds like something I would do. (and have done with other items.) Usually after I do something like this, I lose patience, my inner-bubba comes out, and, well... the fix is worse than the problem. This is why I left my car with my mechanic on Saturday with the GMPP part number for a new mini-starter.
Old Mar 26, 2007 | 08:28 PM
80TexasC3's Avatar
80TexasC3
Bingo! Added two shims and the problem is fixed! Turned over just as quickly as the stock starter and is much quieter now.
Old Mar 26, 2007 | 11:27 PM
Big2Bird's Avatar
Big2Bird
Old Mar 27, 2007 | 01:23 AM
bobs77vet's Avatar
bobs77vet
good job!
To Starter Shims (help)
