I'm having the same problem. All fuses are good and dash lights worked one day and then quit. Headlights, tail lights and brake lights work, just not the dash. Was going for switch next.
The headlight switch also contains a wire-wound reostat (old fashioned word for an electrical potentiometer). It often (eventually) will burn out (open circuit), this causes the dimmer function to fail. However, even if the wire is burn out, the gauge lights should still operate at maximum intensity. Turn the headlight switch to the maximum clockwise position (or is it maximum counterclockwise). If the wiper on the reostat is ok, you will get the lamps to glow at maximum intensity. However if the wiper on the reostat is burn out (open citcuit), there will be no power to the lights regardless of where the headlight switch is rotated too. A failed headlight switch wiper is a possible cause of your problem.
My reostat wire burnt out on my 68. This wire can get very hot, as evidenced by heat damaged discoloration on the headlight switch connector. I installed a new NOS switch. I replaced my center consol gauge lights with LED's to reduce current draw and hopefully heat loading on my new reostat. I left incandescent lights in the speed and tach. (The stock dimmer function will not work with all LED's.)
I had the same problem no blown fuses and the switch was good. I was losing power on the wire feeding the dash lights. I just ran a jumper wire from the fuse block to the dash lights. There is a terminal on the fuse block that is for the dash lights.
Is it hard to check the switch with a meter--if you know where to check?
Thank you for the info
Originally Posted by ESU
Check the fuse for the brake lights. GM linked the two so that if your brake lights went out the dash lights would go out as an indicator,
ESU
