stroker kit help!
Old Mar 26, 2007 | 12:38 PM
pin_point527's Avatar
pin_point527
Default stroker kit help!
i've been looking into Eagle street and strip stroker kits and i see that the come in two different versions: internally balanced and externally balanced (which includes the harmonic dampener and flexplate) but for some reason they seem to have priced the internally balanced kit, which comes with less, higher! is there something im missing here? dont you always need a harmonic balancer and flexplate anyway? please clear up my confusion!!
Old Mar 26, 2007 | 03:36 PM
evalu8r's Avatar
evalu8r
The internal balanced is supposed to be stronger and smoother. And you can use any neutrally balanced harmonic balancers and flywheels.
Chris
Old Mar 26, 2007 | 03:49 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
The internally balanced kit is priced higher because the rotating assembly is balanced on a machine, an extra, more costly step. The internally balanced assembly is a better option. You use it with a neutral balanced damper and flywheel or flexplate.
Old Mar 26, 2007 | 04:02 PM
pin_point527
ok, but you still need a neutral harmonic dampener? or can you get by without it?
Old Mar 26, 2007 | 04:28 PM
63mako's Avatar
63mako
Your stock one is neutral balance. If you want to upgrade you buy a neutral balance damper. All small block balancers are neutral balance except the 400 or an aftermarket made for external balance motors. It cost $250 to get my assembly balanced.
Old Mar 26, 2007 | 06:27 PM
pin_point527
I see, thanks for the info! I hope I can get this project rolling asap!
Old Mar 26, 2007 | 07:31 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I would bet the internally balanced kit has a forged crank and the external has a cast crank
Old Mar 26, 2007 | 08:09 PM
pin_point527
they said it can be either way
To stroker kit help!
