Spark plug wire suggestions....
Old Mar 26, 2007 | 01:23 PM
alanbl's Avatar
alanbl
Default Spark plug wire suggestions....
I'm installing Hooker headers on my '72 sb and my plan is to route the plug wires either over the valve covers or along the bottom of them and then down to the plugs using looms to hold them in place. I think that I should be looking for some high temp shielded or insulated wires. Can anyone point me in the right direction?
Thanks.
Old Mar 26, 2007 | 01:37 PM
jimvette999's Avatar
jimvette999
I like to make my own out of MSD 8.5mm bulk wire for a custom fit. Comes in red or black
http://store.summitracing.com/partde...5&autoview=sku
You'll need the good crimpers if you go this route and of course the ends/boots. MSD sells all the above.
crimper http://www.jegs.com/webapp/wcs/store...0002_747779_-1
Old Mar 26, 2007 | 03:07 PM
Hvymtlc5's Avatar
Hvymtlc5
I buy prebuilt wires (at least 8mm).... and use these looms to keep the wires off the headers.
You can use whatever works....doesn't always have to be expensive....
Old Mar 26, 2007 | 04:00 PM
Kid Vette's Avatar
Kid Vette
I use Moroso looms.
Old Mar 26, 2007 | 04:11 PM
SIXFOOTER's Avatar
SIXFOOTER
Nicely done, also my preference, custom built
Old Mar 26, 2007 | 04:19 PM
alanbl's Avatar
alanbl
Originally Posted by Kid Vette
I use Moroso looms.
Very nice! Thanks, especially, for the pic. Seems that the custom route is the way to the best fit.
Old Mar 26, 2007 | 04:40 PM
Ironcross's Avatar
Ironcross
I like to keep them simple and a clean looking engine done with universal sets and 90 degree plug ends. Attach to the plug and run them underneath and up the back to the distrubutor shorting them if necessary at the cap. Early Vettes use the same locations but under shielding. Camaros are merely 'Baby Vettes' and you can get the idea from here even with the 2 1/4 primaries there is all kinds of clearance from the hot pipes......
Old Mar 26, 2007 | 07:25 PM
The3's Avatar
The3
I used MSD 8.5 mm wires and a loom bracket from Summit. I was going to use heat shields or boots but since the wires are very secure, I think I will do without.
Old Mar 26, 2007 | 07:47 PM
MN80Vette's Avatar
MN80Vette
I burned through 4 sets of "high temp" plug wires when I had stainless steel block hugger headers. I switched to full length ceramic coated headers and Jacobs's 8.5mm ceramic spark plug wires. They are pricie, but I expect them to last much longer.
Here's a look at the ceramic boots from below:
This pic shows a ball milled wire loom to match my valve covers. (Vortec heads = center bolt valve covers.) The wire loom is made to attach to side bolt valve covers, but mine have c.b. adaptors. I had the heat shields left over from previous wire sets and put them on to protect the wires themselves, not the boots.
Old Mar 26, 2007 | 08:21 PM
Oldguard 7's Avatar
Oldguard 7
I use Taylor 8mm wires cut them to desired length and slip on boot.
Old Mar 26, 2007 | 10:18 PM
randyward's Avatar
randyward
I have a set of new ss braided wires if that might help-$50?
Randy
Old Mar 30, 2007 | 07:34 AM
Brian Freeman's Avatar
Brian Freeman
Default Plug Wires
Randy
Randy-- could you give me some more information on these wires you have. I'm looking for a set of SS braided original style wires for a '68 big block.
To Spark plug wire suggestions....
