81 birdcage(pics too)
Old Mar 26, 2007 | 07:00 PM
Joe45's Avatar
Joe45
Default 81 birdcage(pics too)
Here are some pics. of my frame-off. Firewall is off to assess work I need to do. I think overall I am OK. Blasting/Epoxy prime and paint etc. May have to fab some pieces. Will know after blasting.
http://i137.photobucket.com/albums/q.../Birdcage6.jpg
http://i137.photobucket.com/albums/q.../Birdcage7.jpg
http://i137.photobucket.com/albums/q.../Birdcage5.jpg
http://i137.photobucket.com/albums/q.../Birdcage4.jpg
http://i137.photobucket.com/albums/q.../birdcage3.jpg
http://i137.photobucket.com/albums/q...birdcageII.jpg
Please provide input. May purchase a rocker chanel to see if I can use one to repair the originals.
Old Mar 26, 2007 | 07:11 PM
ShinodaVette's Avatar
ShinodaVette
I wish mine looked that good! Looks like a serious project; keep us posted!
Old Mar 26, 2007 | 09:04 PM
JustForFun's Avatar
JustForFun
wow..that one doesnt really look that bad. Im going thru same repair as you. I purchased a NOS rocker channel just today and hope to have it next couple of days. Ill post some pics soon of my rocker swap soon
Old Mar 26, 2007 | 10:04 PM
Artsvette73's Avatar
Artsvette73
I don't see the major problem here.
Old Mar 26, 2007 | 10:30 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
I feel for you,, I just did this on mine in the past months. Have you considered having your rockers manufactured locally,,, I did this and the results were excellent,, much cheeper than I thought too.
[IMG][IMG]
http://i118.photobucket.com/albums/o97/MBandet/InsideLeft.jpg[/IMG][/IMG]
Old Mar 26, 2007 | 10:35 PM
Michel B's Avatar
Michel B
Old Mar 27, 2007 | 06:04 AM
Joe45's Avatar
Joe45
Reason I went this far is to ensure I was addressing all the rust in the cage area. It only took about 4 hrs. to remove the firewall. (Heat gun, drill to remove rivets, and a putty knife.) At leat I'll know condition when it goes back togther. Where did you get the NOS channels if you don't mind telling me? Like Mike B I will be fabbing up the bottom door pillar plate that has the hole for the bushing. I can do that at work. Just have not figured out how to remove it yet without cutting open the pillar itself. I also plan on spot welding a brace from the pillar uprights to my body jig to hold the pillars in location before I remove any bracing. Probably will cross brace as well from left to right across the firewall area just to be sure.Thanks
Old Mar 27, 2007 | 11:06 AM
Black 82's Avatar
Black 82
Cut out the bottom plate of the rocker and then remove the bottom plate of the pillar with the hole for the body mount from underneath. Then weld in fabbed patch panels. It's all basically flat pate with the exception of the turned up ears on the body mount plate.
Old Mar 27, 2007 | 01:41 PM
Joe45's Avatar
Joe45
Black 82.... Thanks, that sounds like the way to do it.
Old Mar 27, 2007 | 05:45 PM
68 NJConv 454's Avatar
68 NJConv 454
not bad at all. Must be nice having everything removed to do the work. Now you'll know for sure that your car is rust free
btw, those are the best cookies in the world in the first picture!!!
To 81 birdcage(pics too)
