Differences between 69 350 HP & 70 LT1
Old Mar 26, 2007 | 09:33 PM
L Holmes's Avatar
L Holmes
Default Differences between 69 350 HP & 70 LT1
I have a 1969 350 350 HP out of a 69 Vette in pieces and it seems to me that aside from the Hydraulic cam it seems to have all the good parts; 202 heads, 11;1 comp. pink rods, steel crank. Am I all wrong here or what?
Old Mar 26, 2007 | 09:39 PM
big_G's Avatar
big_G
The LT-1 had a Holley carb, screw-in studs and guide plates in the heads, aluminum hi-rise intake.
Old Mar 26, 2007 | 11:14 PM
L Holmes's Avatar
L Holmes
OK good info. But the rest of the motor is the same right? Same pistons, rods, crank, etc.
Old Mar 26, 2007 | 11:15 PM
big_G's Avatar
big_G
I believe so.
Old Mar 27, 2007 | 12:19 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Solid vs. Hydraulic cam,..otherwise the shortblocks were the same. The heads castings were the same (041's?), and as Big G noted, the intake and carb were different.
You'd think a solid lifter, holley, and high-rise would all combine for more than 20 HP over a hydraulic, Q-Jet and it's cast iron intake.
The 350/350,..what a great motor!
Old Mar 27, 2007 | 12:51 AM
StickShiftCorvette's Avatar
StickShiftCorvette
I believe that the first year LT-1s were generally considered underated for HP. They were closer to 390 HP based on the gross ratings.
Old Mar 27, 2007 | 01:50 AM
Ironcross's Avatar
Ironcross
The 70 LT1 is the only small block with factory 'pink' rods. Very rare and expensive at todays prices for a set.
Old Mar 27, 2007 | 02:32 AM
DZRick's Avatar
DZRick
Are you sure?
I was under the impression that they were also used in the DZ302 at the very least.
Old Mar 27, 2007 | 07:43 AM
HP Hunter's Avatar
HP Hunter
Default LT-1 Components
The heads were the #186 castings on these LT-1's. 2.020 intakes, 1.600 exhausts, and screw-in studs with 5/16" flat guide plates.
Same heads used on '69/'70 Z-28's. The '69's had no guide plates, they started on the '70.
The factory connecting rods had the letter "O" cast into the cap half and they are the "pink" series. The same letter "O" was used on the original rocker arms. Denoted slightly longer slots.
Harry P. Hunter
Old Mar 27, 2007 | 10:54 AM
pws69's Avatar
pws69
Originally Posted by DZRick
Are you sure?
I was too!
Old Mar 27, 2007 | 11:45 AM
yungn71's Avatar
yungn71
Default pink rods in '71 LT-1
I have a 71 LT-1 motor that was purchased across the counter from a GM dealer in the Feb-Mar time frame in 1971. It had (and still has today) the pink rods with all the correct codes and even the pink tint paint markings. I would believe that other than the 70 LT-1 corvette engine also contained these rods. GM was not known for their strict adherence to their own standards.
Old Mar 27, 2007 | 12:23 PM
Barry's70LT1's Avatar
Barry's70LT1
Here is a page from the NHRA rule book from the early 70s.
NHRA factored the '70 LT-1 with 400 HP.
Also, 350/350 engines had "pink" rods.
Thanks, Barry
Old Mar 27, 2007 | 08:10 PM
stingr69's Avatar
stingr69
Are you sure?
The 302 was produced with Pink rods BUT they were slightly different than the Pink rods used in other applications. The 302 used a full floating piston pin retained with spirolocks. The small end of the 302 Pink rod had a (very expensive) babbit plated pin bore to accomodate the full floating pins. These special Pink rods were not used in any other engine.
The LT-1 was produced with presed pin non-floating style rods and did not have the expensive babbit plated small end bore.
-Mark.
Old Mar 27, 2007 | 08:59 PM
gkull's Avatar
gkull
The NHRA performance factor sheet shown above just includes balancing and blue printing the block. Real world HP - not factory. To get into the NHRA stock catagories every one cheats.
Balance and attention to detail counts for a few more HP.
You have a nice 350 My 79 stock bottom end L-82 forged crank and rods never broke with many times over 7000 rpm with B&B and .030 flat tops. I still have it with smoked pistons. I used 200+ cc heads and single planes
Old Mar 27, 2007 | 09:05 PM
dennis's Avatar
dennis
Harry P. Hunter
Old Mar 27, 2007 | 11:10 PM
73, Dark Blue 454
Clarification,..according to Colvin's "Chevy by the Numbers",..on 1970 Vettes, head casting number 3947041 was used for both 350 HP and 370 HP engines. Casting number 3927186 was used for 300 HP and 370 HP in 1970 (though the 300 horse head would have had smaller valves). And casting number 3927187 was a 350/350 Corvette only head.
FWIW,..
Old Mar 28, 2007 | 03:30 PM
dennis's Avatar
dennis
FWIW,..
Not exactly. The 3927186 head was used for the base, 350hp and 370hp. According to the NCRS new tech manual. Also, 3927187(L-46) and 3973414(LT1) were spec'd and may or may not have been used.
I can say with absolute certainty, that at least one 3927187 was used on a 70 L46. THat would be mine. My other head being a "186 .
To Differences between 69 350 HP & 70 LT1
Old Mar 30, 2007 | 02:08 AM
Oldguard 7's Avatar
Oldguard 7
Why are they called pink rods? I see you mentioned that they had pink tint paint markings. Can anyone post a pic?
Old Mar 30, 2007 | 08:14 AM
HP Hunter's Avatar
HP Hunter
Default Pink Rods
The dab of the pink paint was how the rods got to be called pink-rods!
You shouldn't count on identifying the rods any longer by the paint. Most of the it is gone by now due to working with and cleaning the rods. The caustic soda in most hot tanks will eventually remove the color.
If the letter O is forged in the caps they are pink rods.
If anyone happens to be wanting any of these original rods, with no damage ever, drop me an e-mail. I have friend who restores nothing but the Z-28's and LT-1's. He usually upgrades the rods and has a few sets around.
Harry P. Hunter
Old Mar 30, 2007 | 11:19 PM
Oldguard 7's Avatar
Oldguard 7
How about the LT-1 pistons? Can you buy the same type dome pistions? I have seen some replacements but the dome does not look like the dome on the original pistons.
