Cam won't fit into block!!!!???
Old Mar 27, 2007 | 10:02 PM
oregonsharkman's Avatar
oregonsharkman
Default Cam won't fit into block!!!!???
Yeah thats right, After spending $800 on getting my block hot tanked, decked, clearanced for stroker crank, align honed, bored .030 over and cam bearings installed, my cam will not install into the block. It won't make it past the first bearing.
The block is a 350 4-bolt 010 casting, cam bearings are clevite 77 "good ole" standard cam bearings. Cam is a Comp 286HR retro-fit hydraulic roller. I tried a second cam with the same results. The machinist came highly recomended by a local engine builder, but for some reason the guy always acted like I was bothering him and I was some sort of dumb $hit....( I am an engineer )
Unfortunately I had the machine work done about 1 year ago and was not able to spend the time or money to complete the build. I decided to take the block to a different machinist/shop today. He tried to put the cam in....same result...at least I am not crazy. I thought about dealing with the original machine shop/guy but honestly I would rather not screw with it. So for now the block is in a new shop for new bearings and test fit with my cam.
Has anyone else had this happen? There didn't appear to be any ridges or imperfections in the bearing....it felt smooth. It just wouldn't fit the cam!!!!
Old Mar 27, 2007 | 10:09 PM
sdonnelly's Avatar
sdonnelly
Unlikely, but do you have your fuel pump installed on the engine?
Old Mar 27, 2007 | 10:10 PM
HP Hunter's Avatar
HP Hunter
Default Cam Problems
Occasionally this does happen. Normally it's just a matter of reinstalling a bearing or two. It sounds as though the very front one may have not gone in exactly straight. You will have to start over. Hope you didn't assemble the short block first there. It's not repairable with the crankshaft and rods in.
When doing an assembly you always put the cam in first. An up to par shop will try a cam in the block before it leaves the store.
Harry P. Hunter
Old Mar 27, 2007 | 10:11 PM
oregonsharkman
No...bare block on a stand with only cam bearings installed
Old Mar 28, 2007 | 01:04 PM
sperkins's Avatar
sperkins
Luckily, it's not that big of a deal - only a pain in the ***. R&R the cam bearings and you'll be fine.
Old Mar 28, 2007 | 03:52 PM
Tom454's Avatar
Tom454
I've run into it.
I have the $125 "Professional" cam bearing installation tool you see in all the hot-rod mags... (as opposed to the $69 Chevy only tool). It's a series of collets that adjust to the cam bearing's ID, and then the cam bearing is tapped into the block using a driving rod and a hammer... like the ones in Summit. I've used it for 35 years. Suddenly, the good o'l bearings can't take the abuse of being "tapped" in anymore.... I think they are softer than previous. They mushroom, and the cam cannot be installed.
The solution is to buy the $600 tool that pulls the bearings into place via a threaded rod. Of course, for $600 you get more than a piece of Home Depot threaded rod... but for the average DIY guy, $600 is too much.
In certain engines, the cam bearings ID gets smaller as you go front to back, even though the OD is the same. If you install them out of order, the cam won't go in. (FYI)
http://www.autozone.com/servlet/UiBr...3d8004e4e4.jsp
Old Mar 28, 2007 | 04:02 PM
L88Plus's Avatar
L88Plus
Check to see if there's a small lip on the edge of the bearing that's keeping the cam out. That can be removed with the edge of a sharp knife and you won't have to R&R the bearings. I've seen it quite a bit on the newer LS stuff. By the way, a good shop should check the bearings for burrs and test fit a cam every time, IMHO.
Old Mar 28, 2007 | 04:50 PM
general69's Avatar
general69
I Hope You Installed The Bearings In The Right Order.
They Are Each A Different Size, Larger In Front To Smaller In Rear Inside Diameter.
Old Mar 28, 2007 | 06:35 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I though about this when the post first startted, but the back cam journal needs to fit into the smallest cam bearing, so this shouldn't be an issue.
Old Mar 29, 2007 | 12:45 AM
tlrs819's Avatar
tlrs819
Had this happen a couple of times back in my engine building days. I once used a brake cyl. hone to smooth out a bore in the block before installing the bearing for the 3rd time so it wouldn't crush too much. I dont think it ever happened on a sbc, I think it was a 2.8 v6 and maybe a ford v8 of some kind. Being the front bearing, I wonder if he tried to install it from the front and got it a little crooked??? Maybe he was too lazy that day to take it off the engine stand to put it in from the back for good alignment?
Old Mar 29, 2007 | 10:24 AM
oregonsharkman
All the work was done by a machine shop that came highly recommended by a local engine "guru". In addition to cam bearings, they also clearanced the block for stroker crank, bored .030 over, etc etc. Everything else looks fine, just the bearing are screwed up.
Old Mar 29, 2007 | 10:55 AM
Tom454's Avatar
Tom454
Originally Posted by oregonsharkman
All the work was done by a machine shop that came highly recommended by a local engine "guru". ...
...... just the bearing are screwed up.
Oops.
To Cam won't fit into block!!!!???
