Trailing Arm Bushing
Old Mar 28, 2007 | 07:19 AM
bbvette69's Avatar
bbvette69
Default Trailing Arm Bushing
I have a new set of factory style bushing's with new sleeves and washers and can't squeeze them together enough to flare the sleeve.Do you have to use the washer's?
Old Mar 28, 2007 | 11:28 AM
Tom454's Avatar
Tom454
There is a special tool to compress the rubber to the point where the sleeve can be flared into the special beveled washer.
http://www.madvet.com/shop?frame=4.158.1415
Old Mar 28, 2007 | 05:24 PM
bbvette69's Avatar
bbvette69
We are using a 2 ton press but can't squeeze the bushing's enough to be able to flare the end of the sleeve. Is there different length sleeves?
Old Mar 28, 2007 | 05:48 PM
GTR1999's Avatar
GTR1999
I don't like that tool Tom shows. The clamping part is ok but I don't know how well the flare is going to come out hammering on it. The tool I made is similar but I am able to screw the flare tool in to load the tubing after completely compressing the sleeve.
Old Mar 28, 2007 | 10:43 PM
Jesse's Avatar
Jesse
Retired Admin
Founder St. Jude Fundraiser
Moved to Tech section...
Old Mar 29, 2007 | 07:05 AM
Tom454's Avatar
Tom454
I don't like it either. I bought one a long time ago, used it once, and tied it to a rope for a boat anchor.
Actually, it bent when I used it the first time. I had to straighten it with my press to use it on the second bushing.
But... a lot of people have used it successfully from what I can tell here on the forum. I suspect it works well if the replacement rubber bushing is "soft".
Old Mar 29, 2007 | 07:07 AM
Tom454's Avatar
Tom454
It takes a lot of pressure to compress it.
I have a 12 ton and a 20 ton press.
I'm not aware of different length sleeves.
To Trailing Arm Bushing
