80 Hood Height Adjustment
Old Mar 28, 2007 | 01:35 PM
empotoma's Avatar
empotoma
Default 80 Hood Height Adjustment
I have been stripping my 80, and just realized that the hood across the front is not level. The driver's side is raised a little over a 1/4 inch while passenger's side is recessed about the same. I looked at the front hinges thinking that there may be an adjustment of some kind. I was thinking that I could shim the passenger's hinge a little where it attaches to the hood, but there doesn't seem to be a way to recess the driver's side hinge so that the hood is relatively flush with the body. Am I missing something? Any suggestions are appreciated. Problem is I never noticed this before, and now it's going to make me nuts!
Thanks,
Ed
Old Mar 28, 2007 | 02:30 PM
SIXFOOTER's Avatar
SIXFOOTER
The shims go between the bottom of the hinge and the fender skirt. It it is too high and no shims to remove, I don't know what to tell you.
Old Mar 29, 2007 | 09:38 AM
joseph farrell's Avatar
joseph farrell
2nd Gear
Default header bar
you should check where your header bar is bonded to the nose at the front of the hood opening. i have fixed a couple cars with maladjusted hoods in this area by rebonding the nose bar. look and see if it is loose. this problem is a lot of times accomponied by poor fitting headlight covers / broken headlight frames.
To 80 Hood Height Adjustment
