Possessed
Old Mar 29, 2007 | 04:26 PM
VETTE077's Avatar
VETTE077
Default Possessed
Just cruising down the road my courtesy lights decided to come on then go off and come on again seversl times,It wasn't like a loose connection they come on and go off.Both switches seem to be ok.Any body ever have this happen?
Old Mar 29, 2007 | 04:28 PM
SIXFOOTER's Avatar
SIXFOOTER
sounds like you have a switch grounding somewhere. Light switches are in the door jam at the front of the door.
Old Mar 29, 2007 | 08:37 PM
DeeVeeEight's Avatar
DeeVeeEight
I had a similar issue. I had the 4 way flashers on (yeah I broke down) and the interior lights would flash on and off too. WEIRD! It seems to be a poor ground at the headlight switch, if I wiggle the switch the problem goes away.
Old Mar 29, 2007 | 08:46 PM
Binnie77's Avatar
Binnie77
Does your car have a courtesy light timer? I had the exact same problem and it was the timer.
To Possessed
