Ceramic Headers - Cleaning or Polishing
Old Mar 30, 2007 | 06:53 PM
clast's Avatar
clast
8th Gear
Default Ceramic Headers - Cleaning or Polishing
I've installed Jet-Hot ceramic side Headers a couple of years ago and notice that the headers are covered with some spots this year that don't clean off. Is this a common problem with ceramic coated header? Has anyone has a similar experience and can they be cleaned?
Old Mar 30, 2007 | 08:17 PM
70vert's Avatar
70vert
Banned Scam/Spammer
Mothers and elbow greese. A little of the former a lot of the later.
Old Mar 30, 2007 | 09:43 PM
clast's Avatar
clast
8th Gear
I've tried bit of chrome polish with an eletric polisher and even though I got a nice shine the spots were still apparent. I'm afraid to use something more abrasive as it might wear the ceramic finish. Do you recommend any particular product that you've had experience with?
Old Mar 30, 2007 | 10:02 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Treat them as you would a polished aluminum finish...
Old Apr 3, 2007 | 05:52 PM
PureSilver's Avatar
PureSilver
Whatever you do, DO NOT use a caustic or acid-based cleaner. Once the ceramic gets etched, it will be forever dull and cannot be polished. See: "http://www.thermaltechcoatings.com/care_and_maintance.htm" for instructions for a similar (but better IMHO) product.
Old Apr 4, 2007 | 08:40 PM
clast's Avatar
clast
8th Gear
Thank you for all your help. I'll give it a try this weekend.
Old Apr 4, 2007 | 08:46 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I guess I will be out there with some Mothers this weekend giving it a shot and seeing what kind of results I can get. The bad part is if it works, having to do both of them. Now that will be the killer.
Old Apr 4, 2007 | 09:20 PM
VETTEVIC's Avatar
VETTEVIC
I used autosol on mine.
To Ceramic Headers - Cleaning or Polishing
