Heater hose ??
Old Mar 31, 2007 | 12:08 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Default Heater hose ??
Just read Eric79's thread but didn't want to hijack:
That connection at the side of the water pump connects to the heater and then returns from there to the engine ???
When I boght my '79 the previous owner had bypassed the heater core because it leaked, I reconnected the hose just like it was --> it worked, why change it ??
It seems that both connections can be plugged and I can get rid of that hose (see pic) ??????
Old Mar 31, 2007 | 12:12 PM
Durango_Boy's Avatar
Durango_Boy
As far as I know it's safe to plug. Many of the TPI and TBI water pumps have that bypass plugged anyway, and the coolant to the core went from the manifold. There may be a small risk to your cooling ability, but you can always route the hose again if the plugging creates an over heating problem.
Old Mar 31, 2007 | 12:28 PM
noonie's Avatar
noonie
Nothing wrong with that, but if you have no use for the heater, why waste flow thru the hose? Plug it and send it thru the radiator.
Maybe I'll take my own advice someday.
Old Mar 31, 2007 | 12:40 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
That's basically what I thought: if the engine does not need the flow thru that hose and the manifold then why not plug it ???
I assume the previous owner didn't have plugs in that size and just left the hose nipples in there and connected the two.....
Old Mar 31, 2007 | 06:34 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
No heater, then plug both. Eliminates the possibility of blowing that hose & losing your coolant.
Old Mar 31, 2007 | 07:47 PM
77BuffaloVet's Avatar
77BuffaloVet
I did the same thing on mine...Ha ha...the extra hose and coolant helps keep the engine cool!!!
Old Mar 31, 2007 | 11:33 PM
Big2Bird's Avatar
Big2Bird
To Heater hose ??
