Is my coil bad?
Old Mar 31, 2007 | 04:53 PM
jim2527's Avatar
jim2527
Default Is my coil bad?
Primary resistence is 2.1 cold and 2.7 hot (200 scale)
Secondary resistence is 9.6 cold and 11.6 hot (200K scale)
Secondary seems OK but that primary seems off the scale.
Any thoughts or comments are appreciated.
Old Mar 31, 2007 | 05:10 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Jim if you have a service manual,Any year, it should give you the values of the coil. Its in the Engine Electrical section
Old Mar 31, 2007 | 05:15 PM
jim2527's Avatar
jim2527
I have it but I like to double check electrical things (not my strong point)...
Manual says .35-.55.
OK then, any coil recommendations?
Jim
Old Mar 31, 2007 | 08:28 PM
Roughrider's Avatar
Roughrider
An oe type coil is all you need unless you do some racing or have an aftermarket high performance ignition system.
Check some prices on oe compared to MSD, Pertronix, etc., and see...you may find the hi-po stuff to be no more expensive. Buy them if you want, but for street use, I doubt if you'll see any improvement in driveability or performance over oe, just look flashier.
Last edited by Roughrider; Mar 31, 2007 at 08:30 PM. Reason: Wanted to edit my reply and add something.
Old Mar 31, 2007 | 10:39 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Not trying to insult you or anything, but I need to ask. Did your meter "zero out" to zero prior to the measurement? Some meters will have an ohm or two of offset on them, which either needs to be adjusted out or calculated out in the final measurement. Just need to know before we blame the coil.
Old Apr 1, 2007 | 08:25 AM
jim2527's Avatar
jim2527
I'll go check it...please hold.
Set on the 200 scale it reads 1(blank)(blank).(blank)
Its an Actron digital multimeter.
Thanks,
Jim
To Is my coil bad?
