should coolant bubble back into overflow??
Old Mar 31, 2007 | 06:19 PM
tellcom2001's Avatar
tellcom2001
Default should coolant bubble back into overflow??
i have a 79 vette and today i drove it home parked in the garage and shut it off and heard the anti freeze bubbling back into the over flow is this normal??? never noticed it before
Old Mar 31, 2007 | 06:41 PM
hosspowerinc's Avatar
hosspowerinc
Its normal. When the coolant gets hot it expands and goes into the overflow tank. When you shut your engine off the coolant will pick up a little extra heat because its not being cooled by the fan anymore. As everthing starts to cool back down coolant will then be drawn from the reservoir back into the radiator.
Old Mar 31, 2007 | 07:05 PM
jim2527's Avatar
jim2527
As long as your overflow is at the 'minimum' or 'cold' line when cold your good to go.
Old Apr 1, 2007 | 12:40 AM
mooneyd's Avatar
mooneyd
Normal, not to worry. There's a reason it's called an overflow tank
Old Apr 1, 2007 | 09:20 AM
ghoastrider1's Avatar
ghoastrider1
just be worries if you see lots and lots of bubbles in the coolent,accompied with/by coolent loss and or white smoke or coolent in the oil. What you have ,sounds normal.
To should coolant bubble back into overflow??
