Talking about the alt bracket not the ps pump bracket. Funny it is not listed on their site, might be the second one just flipped over but it is not using the same shims. Going to call their customer service Mon but was hoping to place an order in time to ship Mon morn.
And yes I want a pasenger side alt bracket that mounts to the head.
It does look like the same bracket but the lower pic has it bolted to the head and wp so no sure if the holes are in the same location. I can shim it to the right spacing.
that is just what I need! I am also in need of a passanger side mount but do not like bolting to the water pump. When you get the part number please post it.
Originally in my previous response I stated that this bracket application was for a BB. I immediately questioned that and removed that statement from my answer. Checked further this morning and yes it appears that the pictured bracket is indeed intended for a BB engine.
Only place I know of that has bracket for passenger side SBC is :
Just flippin' through a Jeg's catalogue, and found some brackets. Not sure
of your application, but thought I would pass it along to you.
- Moroso - upper drivers position(same as above) - PN 710-63842
- Jeg's - lower drivers position - PN 555-50542
Of interest is this one which diagram shows being installed upper pass. side position.
- Delcotron - (with short water pump) - PN 710-63825
- Wysco also makes a polished aluminium bracket with tensioning hardware that looks awesome - I'll be putting this one on my list!!! PN 938-WB4304
This is from their most recent catalogue page 149-P, listed under Alternators & Connectors. Or check them out at WWW.Jegs.com..
