dry sump
Old Apr 1, 2007 | 04:21 PM
Belgian1979vette's Avatar
Belgian1979vette
Default dry sump
Did anyone ever install a dry sump system in their C3, if so, is there really any advantage in using it ?
Old Apr 1, 2007 | 04:24 PM
Gordonm's Avatar
Gordonm
Unless you are racing and constantly turning a lot of rpms NO. For the street a wet sump with a good baffled pan is all you will need.
Old Apr 1, 2007 | 05:02 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
i may be running a dry sump system, only because i got a good deal on an aluminum small block that is setup for dry sump.
otherwise i wouldn't bother.
Old Apr 1, 2007 | 05:15 PM
Twin_Turbo's Avatar
Twin_Turbo
it's a great way to rid yourself of a bunch of those euros for sure
turtle..did you get that block fixed?
Old Apr 1, 2007 | 07:09 PM
redvetracr's Avatar
redvetracr
would be cool on the street...for the race track absolutely, I wouldn`t race without one.....I have some extra dry sump stuff if anyone serious is looking for parts...three stage Weaver pump and a couple of Corvette specific oil pans and a Moon tank..... ...redvetracr
Old Apr 1, 2007 | 08:50 PM
Oldguard 7's Avatar
Oldguard 7
What is your take on the new Z06? It uses a dry sump system and it is a street vehicle. Marketing maybe?
Old Apr 1, 2007 | 09:16 PM
turtlevette
It was also designed to race. The C5 guys are always talking about oil starvation so it is indeed a necessity to make a hot car like that live on the road course.
TT,
i'm in no hurry to put together the aluminum engine. Sound familiar?
In the mean time i'll look for anyone that wants to trade for a wet sump
Old Apr 2, 2007 | 12:36 AM
Big2Bird's Avatar
Big2Bird
Is this part of the "I buy the cheapest s--t I can find" theory?
Old Apr 2, 2007 | 02:51 PM
turtlevette
you catch on fast......sparky!
Old Apr 2, 2007 | 03:20 PM
Belgian1979vette
Ok, as i already thought the only advantage is the fact that the pan is not so large, which gives the chassisbuilder the opportunity to put the engine lower, thus resulting in better road behavior. For a normal Corvette chassis the advantage is thus 0
Old Apr 2, 2007 | 03:45 PM
Twin_Turbo's Avatar
Twin_Turbo
actually it's more "I thought I bought the cheapest **** but I bought the wrong **** and it'll take a bunch of money to make it usable so now I'll have to patiently wait for more cheap **** to come on my path to complete it"
Old Apr 2, 2007 | 03:48 PM
Twin_Turbo's Avatar
Twin_Turbo
There are many more advantages apart from lowering the engine, depending on the system, like rockerbox and or lifter valley scavenging, easy to plumb in spring oilers, pulling a good vacuum in the crank case (better ring seal), placing the sump tank in such a position that it improves the weight distribution......
Old Apr 2, 2007 | 03:57 PM
turtlevette
That sums it up quite well.
Anyone wanna dump a complete dry sump system for say $200?
There ain't that many cheap used aluminum wet blocks out there.
Old Apr 2, 2007 | 04:00 PM
68 NJConv 454's Avatar
68 NJConv 454
If the engine is lower then doesn't that lower the entire drivetrain since you would want to retain the driveshaft and differential pinion angle?
Again, lowering the engine helps with the center of gravity, but even then the only place you would notice the difference is on an auto-x race track...and in that event a dry sump should be required anyway.
Lowered dry-sump engine & drivetrain and super stiff suspension would yield you a nice trackcar but not an enjoyable street car.
Old Apr 2, 2007 | 04:03 PM
Twin_Turbo's Avatar
Twin_Turbo
200$ for a pump, tank, pulley, lines, tank, breather tank...??? ain't gonna happen.
If you lower the engine it'll still have to be at an angle, you could play around with it but it would have to be around 4 deg. down, that means the trans tailshaft will be down also, if you angle the diff up 4 deg. that can stay in place.
Old Apr 2, 2007 | 07:23 PM
redvetracr's Avatar
redvetracr
the chassis builder wants the engine lower, the engine builder wants a deeper/wider oil pan to get the oil away from the spinning crankshaft.
...redvetracr
Old Apr 2, 2007 | 07:24 PM
redvetracr's Avatar
redvetracr
in a word "NO"....but I hope that works out for you......
To dry sump
Old Apr 2, 2007 | 07:25 PM
Big2Bird's Avatar
Big2Bird
Dry sump=Dry wallet?
Old Apr 2, 2007 | 08:01 PM
turtlevette
Ya'll don't know me very well, do ya?
I'll make a tank from a coffee can before i pay more than that.
Old Apr 2, 2007 | 08:46 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I'd get one if it was like $500 Minus lines
Down the road
Although I may be racing something else soon that already has one plus 800 hp
