Gear vendors overdrive
forgetaboutit....
gotta be at least 30% and more for that kind of bux.....
by my calculator a 20% reduction would mean a 336 (roughly) rear, same as I had/have now with the muncie....and 80 mph cruise was like 4k rpm.... so 3200 or so....with GV OD....
and for that, they want pushing 3 grand for the total package installed??? I can't see it....
I CAN see a Keisler these daze...or a AOD....but the GV unit is surpassed these daze by other way to get there....
IMO....
M22 4-SPEED Close Ratio - showing clutchless options
Axle Ratio 4.11
Trans Ratio Final Drive Ratio
1st 9.02
Over 7.02
2nd 6.72
Over 5.23
3rd 5.25
Over 4.08
4th 4.11
Over 3.19
The real difference according to their website: In the 1/4 mile you get 1 clutchless shift. They say is good for up to 1 second on ET.( I doubt that) On the highway at 80 MPH a 4.11 is winding pretty hard. A 3.19 final drive ratio would be a real noticable difference. The downside is the price $2600. I am leary of the TKO. My dyno sim shows almost 700 HP and similar torque with the nitrous. I have heard of less power taking out the TKO's especially on the 4th to 5th upshift. (They are rated at 600 Ft Lbs) Also think the 5th ratio is too wide and the road race version doesn't give you as tall of final as this. I already got a ton wrapped up in this build and $2600 seems like a lot but the cruising capability will be much better with this as well as the fuel use plus lower ET's. An automatic is out of the question, Got to shift! Seems like the ticket but $2600
I think if I was going with a OD I'd look at a 5 or 6 spd.
1) Expense
2) Stupidly long extension and poor fitment issues, you will need to severely hack up your car, and youhave to have a removalable crossmember. The OD adds close to a foot of length onto your Muncie.
3) Robs more horsepower, massive weight combined with rotating mass.
I did several of these for people. I think the old british Laycock design overdrive was cool in the day, but has absolutely no place in a muscle car. Oddly I've driven them and I have to say, I hate them. That just me.
If you want a 5 speed with an overdrive and want an M22 whine just get the new Richmond gear 5 speed with an overdrive and stop messing around.
Here is the link: http://www.richmondgear.com/NEW5withOD.html
1) Expense
First run using it equaled a .5 sec lower ET. Still learning. Cruising on the interstate, wonderful. Off the line, wonderful. Six speed auto trans, wonderful. I realy don't want to give it back to the owner.
GO FOR IT!!!
GO FOR IT!!!
1) did not split 1st gear and will not take back torque from deceleration towing heavy!!!
2) derated my driveline form 1485 series U joints to 1350's (1485 yokes are not available yet)
3) They failed to send all of the parts for the job that they said were in the kit and I couldn't get a straight answer on some installation issues until I complained Loudly
4) 2006 and up Dodge has a medium duty Mercedes Benz tranny not NV5600 OD ratio is .79 Gear Vendors is .78 no effective splitting (need .50)
I tow a 26 ft Custom Exxis tag trailer 14,000 GVW (about 11,000 lbs loaded )and a 10T GVW tag trailer with a JD350 Dozer about 15,000 lbs loaded.
In the end the Exxis was to much for my little dually suburban's brakes (trailer brakes are in tip top condition). 4l80e tranny is a stout unit.
That said... go with the OD 4th gear set for the M22 or the new 5 speed.
I have the ROD 6 speed with Road race gearsets
