CS Alternator Pics
Old Apr 1, 2007 | 08:32 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default CS Alternator Pics
As mentioned in my thread from about a week ago here are some pics of my CS Alternator installed using Durango Boys Paper.
Old Apr 1, 2007 | 10:17 PM
Durango_Boy's Avatar
Durango_Boy
Sure looks good. Are you happy with the swap?
Old Apr 1, 2007 | 10:22 PM
Silver00V6Camaro
Yeah it works great alot better than the summit 100 amp did.
Old Apr 1, 2007 | 10:28 PM
Durango_Boy
Great to hear that. If you have any overheating problems let me know and I'll walk you through how to perform that fix.
Old Apr 1, 2007 | 10:31 PM
Z-man's Avatar
Z-man
Looks pretty good!
Old Apr 1, 2007 | 10:59 PM
Durango_Boy
Here is that paper for anyone else thinking of this swap. The CS130 is the smaller duty version of the CS alternators. The install in the paper applies to the CS144, which does not have the over heating issues, and has almost 100 amps at idle. It's more expensive, but is a heavier duty alt.
http://photos.imageevent.com/durango...%20Install.pdf
Old Apr 2, 2007 | 03:13 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
CS144 has a slightly larger case, too.
Old Apr 2, 2007 | 12:25 PM
DR.Jay's Avatar
DR.Jay
I see in the third pic you have the red wire from the three prong connector attached to the battery terminal, and it appears that the small brown wire goes to the lamp, but the third wire appears to be cut off. Am I correct?
On mine the third wire marked (f) on the plug went to the ignition post on the fuse block.
Old Apr 2, 2007 | 07:33 PM
Silver00V6Camaro
Yes my black wire is cut off. I followed durangos papaer. My Brown wire is attached to the bat post on my hei super coil because its a switched 12 volt source. I do not have factory wiring I have an EZ Wiring harness so i do not have a light. The alt has been doing great this way. If it does go out you can order a cs plug from GM that has resistance built in it to replace the light if you do not have it. But the original alt and the summit alt never had the light.
To CS Alternator Pics
