Interior Dye ,Spray Can or by the quart
Old Oct 14, 2001 | 07:02 PM
71DropTop's Avatar
71DropTop
Default Interior Dye ,Spray Can or by the quart
:confused: I know it's probably a stupid question but should i buy the vinyl prep in the spray cans and spray the color with the gun or just buy all spray cans? Then should there be a clear coat on the DK saddle after the paint??? If someone would just tell me the proper way it would help greatly
Old Oct 14, 2001 | 07:07 PM
Larry B.'s Avatar
Larry B.
Default Re: Interior Dye ,Spray Can or by the quart (71DropTop)
I like to use an auto touch up gun. Spray cans are never as good as good spray equipment. Controlability is the issue when doing touch up work, although some people are very good with spray cans.
Old Oct 14, 2001 | 07:29 PM
Paul L's Avatar
Paul L
I have found the spray cans more than adequate for my purposes. The arm rests and sun visors are next.
[Modified by paul79, 5:32 PM 10/14/2001]
Old Oct 14, 2001 | 07:33 PM
utahrookie's Avatar
utahrookie
I used the spray cans. The seceret is to do a good job clraning and preping the parts. Then spray several light laters. This dye goes on like water and won't cover in the few coats.
I keep a can around for touch up , I havent had any needto use it for a year.
good luck
Old Oct 14, 2001 | 08:08 PM
ddn's Avatar
ddn
Default Re: Interior Dye ,Spray Can or by the quart (utahrookie)
If you're doing several parts, and you have a gun, I recommend the quart. You end up using a LOT of thin coats, and the cans dont last too long. I did a shifter console and a e-brake console with one can, but I would have liked another coat or two.
Old Oct 14, 2001 | 08:30 PM
71DropTop's Avatar
71DropTop
Default Re: Interior Dye ,Spray Can or by the quart (ddn)
I've used a can for a test job and it seems to take about 4 coats and i also did not prime or clean the surface to see a worst case scenario, thanks
Old Oct 14, 2001 | 08:50 PM
daniel77350's Avatar
daniel77350
I did mine with cans. I have to do the dash still, but overall its taken 2 cans of vinyl/plastic paint, and one can of metal/plastic paint(for the console and shifter ****, steering column, etc). I think I can do the dash in one can.
But just a word of advice, if you use the vinyl paint on the E-brake cover, don't put any tape over it after its dry. I did that trying to mask off my e-brake handle, and when I pulled the tape up, most of my paint came up with it, it almost looks like the paint creates a plastic "film" over the part, and now I can keep pulling it off. :eek:
I'll have to redo that part tomarrow...hopefully I can do it in the car, cus i really disslike taking it out of the car.
Daniel
[Modified by daniel77350, 12:51 AM 10/15/2001]
Old Oct 14, 2001 | 08:53 PM
Paul L's Avatar
Paul L
Default Re: Interior Dye ,Spray Can or by the quart (daniel77350)
The dye will not lift if you use a vinyl prep (removes the Armor-All, etc.) and prime first. See my pic for the primer.
Old Oct 14, 2001 | 09:58 PM
slide's Avatar
slide
Default Re: Interior Dye ,Spray Can or by the quart (paul79)
I used 2 quarts when I sprayed all my interior parts, it took almost both quarts to do everything but the seats. I put several coats on to be sure everything was coated good.
Slide
Old Oct 14, 2001 | 10:01 PM
daniel77350
I thought it lifted because I put vinyl paint on a plastic-like peice. The paint I used was for vinyl/fabic. Apparently it can be used on carpet too.
I havn't had any problems on any other peices...and I think the big thing was I put tape on it(good tape)...If I continue to run into problems, I'll strip all that paint off, and redo it with the mid america/ecklers catalogue stuff...But hopefully at that time, I'll have all my peices replaced(going to do it slowly)
Daniel
Old Oct 15, 2001 | 10:56 AM
KenSny's Avatar
KenSny
I did all mine with spray cans. BUT next time, I would use a spray gun for a couple of reasons. The cost of all the cans was probably more than buying a couple of qts or a gal. I really think I did not get the same mix batch when I bought the cans. Some of them were a shade different, but was only noticable if the pieces fit against each other.
Old Oct 15, 2001 | 10:58 AM
KenSny's Avatar
KenSny
Daniel, are you saying that you painted the trim in your car -without- removing it from the car?
Old Oct 15, 2001 | 11:14 AM
69er's Avatar
69er
Active Streak: 90 Days
NJ74Stingray(Frank) used this plastic gun type piece that attached to the top of the spray can.
He did many interior pieces and told me this plastic piece is great.
More spray control.
Plus it only costs about $3.
Old Oct 15, 2001 | 04:04 PM
jsimpson's Avatar
jsimpson
Default Re: Interior Dye ,Spray Can or by the quart (KenSny)
I've used both. The spray cans are thinned WAY too much. Takes too many coats and chips easier on plastic parts. The color is slightly lighter from spray cans. Using quarts is cheaper and looks MUCH better.
Old Oct 15, 2001 | 04:44 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I buy it by the quart and shoot it with my gun. If memory serves, the directions on the can said to shoot it like lacquer. I did that and got good results.
Buy more than you think you need.
To Interior Dye ,Spray Can or by the quart
