Oil pan removal
Old Apr 2, 2007 | 04:24 PM
Freepop's Avatar
Freepop
Default Oil pan removal
74 with power steering
Will it slide out or do I need to unhook the motor mounts and jack the engine up?
Old Apr 2, 2007 | 04:26 PM
Big2Bird's Avatar
Big2Bird
Take out the two 3/8" bolts that hold the idler arm to the frame. The steering will drop down out of your way.
Old Apr 2, 2007 | 05:21 PM
mr303's Avatar
mr303
Unbolt the idler arm and pull the steering arms down and you can remove the sump, I have done this a couple of times now.
Old Apr 3, 2007 | 07:27 AM
Freepop's Avatar
Freepop
Thanks, worked like a charm
To Oil pan removal
