AC/Heater Questions
Old Apr 2, 2007 | 04:49 PM
VictoriaVette's Avatar
VictoriaVette
Default Heater Door Questions
I've started to work on my AC and took my center concole apart to get to the AC/Heater Assy. I also took the passengr side lower dash off to check things out and to replace the cable. My question is when I move the temp arm to open or close the heater door there is a spring loaded switch. I see there is an adjustment on the cable to make sure the door opens and closes all the way. When it gets to the spring loaded switch how far does it have to push it in? All the way or what. Anything else I should check out while I have all of this apart?
