Trans oil cooler...return line?
Old Apr 3, 2007 | 12:07 AM
Topless75's Avatar
Topless75
Default Trans oil cooler...return line?
Which line coming from the radiator cooler is considered the trans oil "return" line? Upper or lower?
I'm installing an aftermarket trans cooler and need to tap in to the return line according to the instructions. Also...does it really matter? The cooler will still cool even if you tap into the supply line, no?
Old Apr 3, 2007 | 12:11 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
yes it does matter.....you want to cool the trans fluid and then heat it to water temp as opposed to cooling it to water temp and then cooling it even more.....cold transmissions shift funny
edit: although that is contrary to what your instructions say???? you may want to get some more opinions on this one..how are you going to use the car? strip or street?
Old Apr 3, 2007 | 12:30 AM
Topless75's Avatar
Topless75
Strictly street use.
I've read two different sets of instructions (one that came with the cooler, the other on a Google search) and both say to use the return line.
Old Apr 3, 2007 | 12:31 AM
SIXFOOTER's Avatar
SIXFOOTER
I have looked all over the place and have yet to find ANYTHING on a minumum operating temp on a transmission. The ONLY thing I have found is keep it under 200, the cooler the better. I would skip the radiator and just go with an external cooler. My personal choice is a dual pass extruded aluminum heat sink type. No moving parts, installed in the slipstream under the car
Old Apr 3, 2007 | 12:52 AM
Topless75's Avatar
Topless75
The car had an external cooler (only) and, in very hot weather (after extended freeway driving), the tranny would "slam" between 1st & 2nd. I assumed this was because the external cooler was too small (it looked tiny...3/8" thick x 6" x 8"). If I turned the car off for a few minutes and re-started all was well (until the next extended run).
So, I installed a new radiator with new lines and hooked them up as per "factory" thru the rad cooling ports. Same problem.
Now, I've got a nice big auxillary cooler to install. I figure if I install this in-line with the rad and it solves the problem, all is good. If the tranny still overheats/slams, then I know I have bigger problems. I'm thinking it is cheaper to try adding a cooler than to automatically assume the tranny is toast and have it rebuilt.
Old Apr 3, 2007 | 09:19 AM
Topless75's Avatar
Topless75
So...does anyone know which line is the "return"?
Old Apr 3, 2007 | 09:23 AM
bobs77vet's Avatar
bobs77vet
no i don't know, but here is some logic.....the top line is the supply line that uses pressure to pump the trans fluid through the radiator top inlet and out of the bottom radiator inlet back to the trans and this also use gravitiy to help the flow
Old Apr 3, 2007 | 09:38 AM
wfo76's Avatar
wfo76
Trace the lines from the tranny. The cooler return line on the 350, 400 and 700R4 as it enters the TRANNY is the TOP line.
Old Apr 3, 2007 | 01:59 PM
Topless75's Avatar
Topless75
So...we have one vote for TOP and one vote for BOTTOM...
Old Apr 3, 2007 | 03:05 PM
2armor's Avatar
2armor
Topless~ crack both lines at the radiator fittings and start the darn thing. Watch your eyes! Sorry. I dont know either.
Old Apr 3, 2007 | 05:02 PM
wfo76's Avatar
wfo76
Not talking about the radiator, find the lines entering the TRANSMISSION and then trace them to the front and see which is which. The top line TOP line as it enters the TRANSMISSION is the return line.
Old Apr 3, 2007 | 05:38 PM
bobs77vet's Avatar
bobs77vet
i have no reason to disagree with wfo76.....
Old Apr 3, 2007 | 05:47 PM
bobs77vet's Avatar
bobs77vet
from the book......"at the transmision the feed line -transmission to cooler is always the lower line and the return line- cooler to transmission is the upper"....wfo76 wins!
Old Apr 3, 2007 | 06:46 PM
Topless75's Avatar
Topless75
OK. Thanks!
Old Apr 3, 2007 | 10:13 PM
Big2Bird's Avatar
Big2Bird
I asked my transmission guy about this today. Bob is absolutely correct.
Old Apr 3, 2007 | 10:18 PM
Big2Bird's Avatar
Big2Bird
Sorry Danny. I checked on this today. In warmer climates such as Kalifornia and Florida, it is not critical. The hydraulic pumping action will bring it up to temp rather quickly. In colder climates, the fluid will thicken and mess up the tranny quickly due to poor circulation/thick viscosity. I get this from my Tranny guy of 35 years, and he reads all the trade rags.
Apparantly lack of quick heating of the fluid is good business in cold climate areas.
Old Apr 3, 2007 | 10:19 PM
Topless75's Avatar
Topless75
Not so sure. That tranny can get pretty hot without any help. I touched the external cooler after running the engine for less than a minute. It was already hot.
From the web:
It is normally preferable to have the external cooler plumbed in series with the return line. This provides the most efficient cooling by about 5%. However, the port at the top of the radiator where the return line exits is kind of a tight squeeze to work with, so you can tap into it at the transmission but this requires running longer fluid lines back to the radiator area (some of us have done this with no problems).
Alternatively, plumb into the supply line. It has slightly less cooling efficiency but simplifies the installation a little bit (no picture available).
To Trans oil cooler...return line?
Old Apr 3, 2007 | 10:22 PM
Topless75's Avatar
Topless75
That's what I've read. There is a temp-controlled bypass valve (thermostat) that recirculates the tranny fluid bypassing the external cooler until it reaches operating temp. They recommend installing these in Northern climates.
Old Apr 3, 2007 | 10:32 PM
Big2Bird's Avatar
Big2Bird
From the web:
I do not claim to be an expert in this. I can only quote people that have never failed me. An aftermarket cooler in the return would be cooler. The rad portion is only to ensure a quick warm up in cold climates.
Since we are referencing the web, check out the install instructions at Bowtie Overdrives, They will only warranty their transmissions when the radiator and aftermarket cooler is installed in a specific order.
Old Apr 3, 2007 | 10:51 PM
Topless75's Avatar
Topless75
Couldn't find it on their site. So...what do they say? Cooler in series with the return line or supply line?
Found it...they require an auxilliary cooler in-line with the return line. They want the tranny temp 30 ~ 50 degrees cooler than the rad temp.
