Changing Holley, canīt tune it.
Bigger Cam
Torker II manifold.
High compression.
So first I changed the distrubitor with HEI.
Endplay: 0.012
Total timing: 36° at 2800 Rpm
Base timing: 17
The old carb ran very well with this.
So now to the problems with the new Holley 670 Street Avenger..
First I changede the power valve, and the jet size acording to Lars´s advise.
Bench set the idle.
Set the float level.
Hooked up so I could read the vacuum, so I could adjust the mixture screws. But I only get around 7 In.Hg?!?!?
When I try to adjust the mixture srews there are none vacuum or Rpm change. It just dies when the mixture screws are to far in.
Everything is pluged, exept the vacuum canister.
Don´t know what vacuum reading I had before changing the carb.
Any advise?
Read all paper about tuning and timing, so I was ready to do this tuning myself. Have prepared it for about 3 months. Know I cant get anyting to work.....
350.
Bigger Cam
Torker II manifold.
High compression.
Holle 670 Street Avenger.
Wisp
I switched to a bigger cam over the winter as well. If it wasn't for the Megasquirt computer controlling my timing only, I'd never get this thing to idel and start at the same time. I'm running 24 deg at 800 rpms in gear with 3inhg vacuum. But to start it I have a 400 rpm cell in my computer which is set at a starter freindly 13 degrees adv. Its basically acting like a start retard box.
But If I cant find more vacuum, then I really need a Vacuum canister thats pullingin the mid 5 In. Hg area? Or?
Wisp
I've got a big cam and tried Lars method. I could not get a stable enough idle to get the idle screws to work.
I changed to ported (no vacuum to the distributor at idle) and it settled down the idle enough to get it idling nicely at 600rpm with only abot 7" of vacuum.
I have only tried ported vacuum becourse I wanted a smooth idle. Have thought of trying ported vacuum instead. I will try tonight...
How did you set you mixture screws? I have read that when you have the highest vacuum reading you mixture screws a set correct. But I cant see any diffrence in the vacuum reading...
With light springs and a faster advance, the manifold vacuum would not stabilize. It started pulling the vacuum advance in too early and would not stabilize.
Going to the ported (carb, no vacuum at idle) the idle would settle down and I was able to tune to most vacuum at about 600rpm.
Itīs connected to FULL MANIFOLD VACUUM.
Right now I have trouble with the vacuum canister not working in the 7 In.Hg area.....
So If I connect it to ported vacuum, the vacuum canister will only come into play under light load. So I just have to hope the idle wont be to rough with ported vacuum....
But I was hoping that I could bring my vacuum up instead..
Wisp
First I've verified my timing is correct. I'm 36* all in at 2500RPM. Hooked to manifold vacuum, I'm at 18* at 850RPM idle.
Recently I installed full length headers, true duals with an x-pipe. So I rejetted my 670 SA. Primaries are now 68's instead of the original 65's.
Resetting the idle was not scientific but worked out OK. I ran the idle screws all in (clockwise) and then back out 1 1/2 turns as a starting point. The engine ran like crap. I then adjusted the idle speed screw until I achieved @900 RPM. I couldn't get a lower idle.
I then started turning BOTH idle mixtures screws 1/4 out (counter clockwise) listening to the engine increasing RPM and idle smoothing out. For each 1/4 turn of BOTH screws, I kept reseting the idle as close to 850RPM as I could get.
Eventually, I achived a very smooth idle at 850RPM. This is where I stopped, popped a top and called it a day.
For your vacuum to be that low at idle with no problems, your cam would have to be running around 240 degrees duration with an LSA or around 108 degrees. I'm assuming that high compression means around 10:1.
The timing is set with the vacuum canister plugged.
This is what i´m running:
http://store.summitracing.com/partde...1&autoview=sku
Dont know anything about cams...
I just cant get the mixture screws to have any effect compared to vacuum or RPM. I don´t se or hear any difference when I turn the mixture screws
Thought of a vacuum leak, but everything is plugged, exept the vacuum canister...
Wisp
I just cant get the mixture screws to have any effect compared to vacuum or RPM. I donīt se or hear any difference when I turn the mixture screws
I ran a cam similar to yours before and it wouldn't idle much below 1000rpm. But I was running a tunnel ram with 2-4's and was able to close the plates enough that the idle screws were effective.
I'm running a BG race demon now and a much bigger cam. At first I couldn't get it to idle until I made sure both sets of plates were open the same, which put me below the transition circuit.
I have 0.020 visible of the transition slot at the primary side, and the same amount of air at the secundary side. Like Larsīs paper says it should.....
So what is wrong....? What happens if the jetting is of????
Running out of options here...... AND WHERE IS LARS WHEN YOU NEED HIM
Wisp
Wisp
