hiddle problem's
But there's a first problem!!!!
Ill taked the car of the towing and ''VROOM'' turn the motor on. Unfurtunatly I can't go take a ride cause there's a snowstorm outside so I just park it in my garage. The cars run really great but suddenly the cars stop. I try to start it but nothing!!! No more battery!!! I boost it and when the car start the iddle stay really high (2500 RPM) and dont want to go down. The iddle stay normal when I push on the little plate on the carburator. When I dont push on the plate it goes HIgh again. I dont know anything yet about vette but I really want to learn about this fantastic car and its the reason why I purchase it.
So please, does some good shepherd could solve my problem??
Thanks!!!!
(sorry for my english im a french canadian!!! but I want to learn!!!!
It sounds like you have a few issues all rolled into one.
You say it died and wouldn't start until you jumped it? Did it run okay and for a long period after that?
I suspect you may have a bad battery, a bad alternator, or both. It would be best to remove both, take them to a parts store that tests such things, and have them tested. If they do not pass then replace them as needed.
The high idle problem as you describe it sounds like the choke. You blip the throttle and the idle lowers and then raises again until you do it again sounds like your choke. Does it still do this even after it's hot?
but the question that turn in my head is why the first time I turned the key "ON'' it run normal and smooth????
I know that the car dont start as much in the next 6 month. Does this can influence??
Make sure the battery cables are tight. I would even disconnect both of them and reattach em so you know they are making good contact with the battery.
Is it to long for the motors to turn at 2500 rpm??
Thanks guy's I really apreciate your help.
THE NEWBI
Some people will say 1 year old gas will be bad but personally I don't think it would be a problem. I would siphon it out and use it in my work van if it was me, tho!
As for the battery, when it's running does the gauge show that it is charging? The fact that your original post says it just stopped running makes it sound like it could be an alternator problem. A properly operating alternator will allow the car to run even if the battery was disconnected. If the alternator isn't doing it's job the car will be running on battery power until there is no more juice left in the battery.
I just went through that with my wifes 98 Malibu! Took 3 batteries to get her home! She got to my brothers and I changed out the battery. Got another 10 miles and I had to change it out again. Got it home and put in a new alternator and the original never recharged battery went back in. Started and ran great. A good battery will actually recover without charging it.(thank goodness I had all the batteries out of my Vettes for the winter!)
Thanks a lot!!!I really apreciate your help!
And yes im a ''new school'' car owner (injected) but I want to learn more about ''old school'' car cause I just love it.
for my problem of battery Ill take a look at my alternator and there was a bad connection on the alternator!!! Thanks god!!!
Thanks again!!!!!
That's the limit of my schoolboy French, but welcome aboard! There are Forum members all over the world, even down here in the Antipodes. Never be afraid to ask a question, but a piece of advice:-
Purchase a good Workshop Manual and an Assembly Instruction Manual for your model year and, although the English may cause you a few problems, most of your questions can be answered there.
For all the other questions, we are here for you.
Bon apres midi et,
Regards from Down Under
aussiejohn
