engine size for c3
Old Apr 5, 2007 | 12:32 PM
slayer2_2's Avatar
slayer2_2
Default engine size for c3
hello i´m just thinking to put the most bigger engine into a c3 i saw until 540 cubic inches from scott shaffirof but i have a dude ¿can i put a 598 c.i. from this guy? www.steveschmidtracing.com thanks for your future help.. guys
Old Apr 5, 2007 | 06:06 PM
TimAT's Avatar
TimAT
You need to find out if he's using a tall deck block. It will fit, but the hassles make it something of a real chore. Headers won't fit, steering box is in the way, overall too high to get the hood shut, I'm sure there are several things I missed too.
Old Apr 6, 2007 | 04:49 AM
a smith's Avatar
a smith
So what do you think it is going to take (frame,trans,rearend) to support that big of an engine? Vegas
Old Apr 6, 2007 | 06:20 AM
TimAT's Avatar
TimAT
I've got a 454 in my C3 right now. It's got the parts book from GM thrown at it- all the GM LS-7/ZL-1 stuff. Frame is stock, Muncie 4 speed and original rear end. The only change is the Lakewood bellhousing.
The only real limit to what will fit is the checkbook. A tall deck block will fit, but you'll need to fabricate a lot of parts. And I saw someone building an 818 cubic inch BB..
Old Apr 6, 2007 | 06:52 AM
slayer2_2's Avatar
slayer2_2
well my frame is modificated lie the twin_turbo member of this forum. I saw a 540 from scoot shafiroff, and it fits well that,s ok. to put this engine i have the same rear end like twin_turbo is heavy duty but sure i have to change internal pinions for other more hardcore. i´m going to put a wwww.abruzzi´s transmission.com it cost near of 4000 dollars and put vbp suspension complete for near of 2400 $ and several things more my idea is win the quarter of mille and please if you put me photos of engines that will fit on my beast i will be pleasured thanks, please put me the internet directions.
Old Apr 6, 2007 | 09:03 AM
norvalwilhelm's Avatar
norvalwilhelm
Header clearance was the big thing for me. The added width of the tall deck block made the motor too wide for the headers to fit. You would need custom headers and that isn't cheap or easy.
You can buy the special intake needed or use spacers.
I was too lazy and went with the 540.
Old Apr 6, 2007 | 10:41 AM
tshort's Avatar
tshort
CI 7-8 Veteran
With a little $$ and fabrication almost anything will fit. There are 2 guys that are in our local group that have tall deck BB's in their c3's. A 598 and a 632. A little firewall fabrication and of course header modification were needed to fit them. I'm not sure either has a vacuum brake booster either. And a TALL hood.
I'm sure either one of them will be chiming in soon...Pef427 or VetteManiac (I think that's Nick's forum name???)
Old Apr 6, 2007 | 10:50 AM
pef427's Avatar
pef427
The 598 will fit. But, I do not have A/C or powersteering/brakes although the car steers/stops easily without it. We have discussed this in the past here so check the old posts or just PM me for any help you may need.
I have a friend with a 632 in a 72 but he has really tricked-out his engine compartment. More for aesthetics than fitment.
-Patrick
Old Apr 6, 2007 | 03:03 PM
slayer2_2's Avatar
slayer2_2
Thanks for your pictures .it´s nice to live in the another side of the atlantic ocean and there are too many people who wants to help you.it´s nice for me and give more power to go on with my car.
well my idea it`s do the best beast as i can do.So first for me the engine had to take 10:1 0r 10´5 :1 more compression i don´t like because i think that don´t have the same resistance than other engine with less compression.The second thing that i wanted is the engine must be fabricated very well. and if you talk that the 540 fits better than 598 i put 540 because this engine has 750 h.p. and it´s enough for me.so if would be possible put me the best 540 that i can buy in america put web directions, price doesn´t matter i want the best fabrication of the engine, you know put and run and have the less problems possibles.THANKS FOR YOUR SUPPORT AND HELP
Old Apr 6, 2007 | 07:01 PM
VetteLS6's Avatar
VetteLS6
Try Breck Racing Engines, I think they have a turn-key 540 that dips into the HP range you are looking for. The rest will need to be done correctly of you will end breaking to many things. Ohio Crank Has some engines they sell turn key with huge number...900hp+++
Old Apr 7, 2007 | 05:35 AM
slayer2_2's Avatar
slayer2_2
i saw beck racing engines and i prefer steve schmidt but ohio crank it´s really good page and have a very good engines but i don´t go to buy now so i have time to deicide. if i finally put 540 from steve schmidt where i have to buy a tall hood? where i have to buy the hardcore pinions for my heavy duty rear end? Thanks for your help ahh and really nice information.
Old Apr 7, 2007 | 07:58 AM
norvalwilhelm
The 540 is exactly the same dimensions as the 396/427/454 on the outside and it will drop right in. The intake decides if you need added hood clearance or not.
Yes a 540 will bolt in like any stock motor.
Old Apr 7, 2007 | 09:09 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Shaffirof builds the baddest big blocks. If $ are not an issue his 540 aluminum is the ticket!
Old Apr 7, 2007 | 09:20 AM
pef427's Avatar
pef427
Norval is absolutely right. If you want a drop in block with minimal work and more HP than should be legal, go with the 540. 427Hotrod has one in his 67 and I believe he's putting out around 825-850 HP and drives it everywhere. I'm sure if he had a powerglide and the right stall converter he would be deep into the 9's. But man I love to hear him shift that beast!
540 is your ticket. Keep us posted.
-P
Old Apr 7, 2007 | 04:46 PM
roscobbc's Avatar
roscobbc
Default 540
It seems that if it costs more or less the same to build-up a 427, 454, 496,502 or 540 (if you are using a new block & crank etc) the 540 is the logical and most cost effective choice. You will comfortably achieve the best horsepower/torque that a 427/454 can give without the 540 even braking into a sweat. Thats on my shopping list. It even rules out thinking about a blower!
Old Apr 7, 2007 | 08:49 PM
norvalwilhelm
How about a 540 and a blower?? 1000 horse is not out of the question.
Old Apr 8, 2007 | 12:02 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Now Norval...THAT's what we like to see..wretched excess!! I love it!!
JIM
To engine size for c3
Old Apr 8, 2007 | 06:18 AM
slayer2_2's Avatar
slayer2_2
that´s very clear for me i´m going to put the 540 baddest of the world and i try put photos and post with you thanks for your help guys well if you think that shafiroff has the best engine i put it but steve´s schmidt it´s so beautiful well when winter comes it deicide it . a strong salute to all quarter runners go for 9 seconds or die.....
Old Apr 9, 2007 | 05:10 AM
roscobbc's Avatar
roscobbc
[QUOTE=norvalwilhelm;1559720445]How about a 540 and a blower?? 1000 horse is not out of the question.
I just knew you would reply as you did Norval. I am interested in the other thread with the small block Procharger set-up and how the heat/cooling air-flow issues will be resolved.
Old Apr 10, 2007 | 11:41 PM
pef427's Avatar
pef427
to wretched excess!
-P
