Aftermarket Flywheel for 72
Old Oct 15, 2001 | 11:48 AM
briang's Avatar
briang
Cruising
Default Aftermarket Flywheel for 72
Will be replacing the flywheel any comments on aftermarket vs. GM flywheel?
Old Oct 15, 2001 | 12:40 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: Aftermarket Flywheel for 72 (briang)
GM flywheels are probably cast where a aftermarket could be billet. A cast flywheel is alot weaker and could if abused fly apart where a billet flywheel is far stonger and less prone to flying apart. An aluminum flywheel is nice but it is harder on the drive train. A motor is a series pulses and a heavy steel wheel smoothes them out where as a aluminum flywheel allows the pulses to be felt. The idle is also rougher with alumimun.
Old Oct 15, 2001 | 06:02 PM
71roadster's Avatar
71roadster
Default Re: Aftermarket Flywheel for 72 (norvalwilhelm)
not to mention that the Hay's billet flywheel isn't that much more expensive than a new GM flywheel. Look it up on http://www.jegs.com
Chris
Old Oct 15, 2001 | 07:34 PM
70PurpleLS7's Avatar
70PurpleLS7
Just my experiance here..
I did the "aftermarket" flywheel with a Hays flywheel. The first problem was with a Centerforce Dual Friction setup. The flywheel was only about 3/4" thick compared to the 1 1/4" thick for the GM flywheel.
Well after having problems with the centerforce, I was informed that I should of installed a "factory" flywheel (GM) rather then aftermarket and they almost didn't warrantee it. So I went with a Hays clutch setup and that seemed to work.
So I decide to get the M22, put it in, more clutch problems, (geometry was off and couldn't engage the clutch) place where I bought the tranny asked what flywheel was in, told him Hays, he told me to rip it out and put in stock GM. That's what I did, and I haven't had a problem since...
Just my .02 :)
[Modified by 70PurpleLS7, 6:36 PM 10/15/2001]
To Aftermarket Flywheel for 72
