Ls2 Engine Swap
Old Apr 7, 2007 | 08:41 AM
corvetteterry's Avatar
corvetteterry
Default Ls2 Engine Swap
i want to put an LS2engine into my 78 vette.has anybodyout there done this .what will i need and how will it fit.
Old Apr 7, 2007 | 09:09 AM
SuprJames's Avatar
SuprJames
Bunch of people doing LS1's and one guy doing a LS7. Do a search of the archeives in both C3 Tech and C3 General.
Old Apr 7, 2007 | 09:17 AM
machineman's Avatar
machineman
You are going to start seeing a lot more LS engines in older cars and the Vettes are a great platform for the engine. I have been building more and more of them for older cars now.
Old Apr 7, 2007 | 10:13 AM
Durango_Boy's Avatar
Durango_Boy
Check out LS1Tech. It's a great forum that will have all the info you need on a swap like that.
http://www.ls1tech.com/forums/index.php?
Old Apr 7, 2007 | 10:25 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I am wanting to do the LS swap in mine. Just not finding what I want for the price I want to pay. Always on the look though. I will find it.
Old Apr 7, 2007 | 10:41 AM
Durango_Boy
What's your range Eddie, I see lots of these motors going at good prices. You can PM me your budget, what kind you look for, and if you need a trans with it.
Old Apr 7, 2007 | 10:42 AM
corvetteterry
i think its a perfect fit i am just wondering about the hook ups and wiring
Old Apr 8, 2007 | 04:40 AM
74batmobile's Avatar
74batmobile
how much are u guys talkin about in labor like? is it even worth it?
Old Apr 8, 2007 | 08:29 AM
Durango_Boy
I've heard a few guys talk about over all from start to finish it took about $10K. That may or may not be transmission too, and expensive kits and fabrication.
Old Apr 8, 2007 | 09:09 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
I think Pat has done his the cheapest. I spent a little more, because I got screwed on a wiring harness and my T-56 was missing all the clutch assembly/bellhouse. I added it up and I'm probably under $5000.
I guess I was kind of forced into doing mine. I had just grenaded a built 700R4 at the track and was looking at spending another $1000 to rebuild it. I also started losing compression in a couple of cylinders from to many 150 shots of nitrous. At that point, the TPI's best time was mid 13's and it wasn't getting any better. My next step was either a BB or something different. I was looking for a BB and stumbled across this LS1. After watching a few new C-5's put down 300+ hp at the rear tires stock, I told myself this is the way to go. Lite and fast.
Most guys fund their swap by selling off all their Small block parts. I sold my S & P TPI, headers, and heads to fund mine. Trust me it was a great trade off.
Old Apr 8, 2007 | 09:12 AM
Durango_Boy
So Budman, did yours cost a total of $5000, or $5000 on top of the motor?
Old Apr 8, 2007 | 10:41 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Mine kinda went like this.
$1800 for the motor and T-56
$100 Bellhousing
$75 flywheel
$200 for Clutch/Pressure plate
$100 Shifter
$250 Master cylinder and Slave
$100 Pedal Assm.
$200 Alum Driveshaft and cut/balance
$350 Wiring harness work (Had to do that twice)
$100 ECM
$75 LS 1 Fans
$150 Exhaust work
$25 Overflow tank
$300 Misc. bolts and hoses.
Total $3825.
You add in all the trips to junkyards, shipping, etc and you quickly get to $5000. I was lucky and was able to design and build all the brackets, so I saved a few hundred there.
Old Apr 10, 2007 | 10:59 AM
Corv3tt3's Avatar
Corv3tt3
What is a good price on an LS1/2 and t56? Most of what I see is a lot more expensive than what I think it should be. For an example some guy on craigslist has an ls1 and t56 that he wants 7000 for. I think that is a little bit out of line since you can buy a new ls2 from SDPC for 5495. Do you just call salvage yards or where do you find these deals?
Old Apr 10, 2007 | 11:06 AM
Durango_Boy
$100 Bellhousing
$75 flywheel
$100 Shifter
$100 Pedal Assm.
$100 ECM
$75 LS 1 Fans
$150 Exhaust work
$25 Overflow tank
Total $3825.
You lucked out finding a motor and trans that cheap. Most people doing this swap will probably pay three times that.
Old Apr 10, 2007 | 03:04 PM
mrvette's Avatar
mrvette
DB, guys, that is what holding me back, about 2 grand or so for the engine in decent shape, no prob.....but it has to be complete enuff for me to do all the accessories also, not too concerned with mounts BUT matching up to the olde tyme SBC bellhousing is a MUST....not ditching my tranny over this, yet again....I got the 3rd tranny in this car now since I had it...and really really REALLY DONT WANNA go there again...
but a LS engine is mighty curious to me....wiring harness is no problem, need the computer and some progremming talent to get rid of all the associated BS I"m sure is in there, just run the damn engine, leave the rest outta there, for christsakes....
Old Apr 10, 2007 | 03:08 PM
Durango_Boy
Gene, I found several complete LS motors, most with harnesses and computers for around $3000. I have not been able to verify this with all of them, but I may end up with a few good solid $3K leads.
Old Apr 10, 2007 | 03:36 PM
mrvette's Avatar
mrvette
Well 3 grand is gettin closer, but does the bellhousing /fly-flex line up?? or is there an adaptor plate type thingy?? tha'ts not cheeeeep....
then there is the engine mounts, I unnersand they are about 80 bux from a guy here on forum...so dooable...
the rest of the plumbing I do....the programming is what got ME stumped though.....
I just recently got this 350 '89 engine running well enuff I can't complain too much, so this project would be off another couple years or so, barring problems....
Old Apr 10, 2007 | 03:38 PM
Durango_Boy
I really know very little about the LS motors and what it takes to swap them in. I'm trying to learn more as it's a question asked here a lot. I just have found a few good prices on '01 or later LS1 motors, which as you know leaves the option for the LS2 and 7 intake manifolds.
Old Apr 10, 2007 | 04:03 PM
72LS1Vette's Avatar
72LS1Vette
The bellhousing for the older transmissions will work on a LS1. There is one hole that doesn't have a corresponding tapped hole in the block. You need a spacer for the flywheel and possibly an extended pilot bearing - neither is very expensive. I started looking into the LS1/Muncie matchup but then I bought a T56.
Engine mount adapters are available from several sources. I think I paid ~$50.00 for the adapters and bought a new set of standard mounts. Test-fitted the engine a couple of months ago and it drops right in.
The electrical system is very self-contained. Provide power to the computer and engine, water and fuel and a few other details and the engine should run.
You can't change the programming without special gear so it might be more economical to have a shop that knows LS1s program out stuff like CAGS and the VATS.
Rick B.
To Ls2 Engine Swap
