Heat riser gaskets
Old Apr 7, 2007 | 06:13 PM
chrisd0729's Avatar
chrisd0729
Default Heat riser gaskets
I'm swapping out the unknown exhaust manifolds that Bubba put on my car next weekend so I'm ordering all the gaskets and hardware now...
There's no riser nor riser eliminator on it now but, I'm adding a spacer. Aside from the triangle gasket on the one side of the riser, does it also get the doughnut type gasket on the other end like on the driver side?
Mid America has a sleeve type gasket for this instead of a doughnut- does this work?
If it matters, it's an 80, with a/c and no emissions stuff.
Old Apr 7, 2007 | 06:35 PM
SEVNT6's Avatar
SEVNT6
There is a donut on the right side. On my Corvette Central exhaust the donut goes around the sleeve in your pic........
Old Apr 7, 2007 | 07:11 PM
chrisd0729's Avatar
chrisd0729
Interesting... so, I need that sleeve AND a doughnut on each side? Any chance someone has a diagram or explanation of how each side goes together from the output of the manifold and the pipe that bolts on to it? Because Bubba has something completely wrong on mine, I can't tell by taking mine apart.
Old Apr 7, 2007 | 07:26 PM
SEVNT6's Avatar
SEVNT6
Go to the Corvette Central web site and put in part# 323040.....
To Heat riser gaskets
