starter problem
Old Apr 7, 2007 | 08:14 PM
injector's Avatar
injector
1st Gear
Default starter problem
1970 small block with four speed. had short in starter.would not stop turning when i turned the key loose. replaced starter, now there is no current from key switch to starter.i have replaced key switch and bypassed clutch switch.still no current to starter. the fuse wire coming from starter to the inside of the car is ok. with the key is in the on position very thing else works. just no current from key switch to starter. is there anyone who can help thanks
Old Apr 7, 2007 | 08:32 PM
SIXFOOTER's Avatar
SIXFOOTER
Stick a test light on the large connection and check for 12v all the tme. Put test light on the S term and check for 12v with someone turning the key to start. You sure you got it connected the same as original?
Ground wire connected and not burned? It goes from the starter bracket to under the motor mount
