Spring cushion cups
Old Apr 7, 2007 | 09:34 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Default Spring cushion cups
What's the trick to peening over the small end? I have a T/A with one missing, and the other T/A's cup has a dent. A forum member generously sent me a pair of new repops, I just need to get them installed correctly.
Old Apr 7, 2007 | 09:41 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I'm not exactly sure of your question. Are you talking about putting the cups in the t-arm?
I had to cut down my poly bushings for it to fit correctly, if your running poly.
Old Apr 7, 2007 | 11:04 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Yep. Replacing the cups in the arms...the small side is peened over to "rivet" the cup in place, but I'm not sure how to do it right.
Old Apr 9, 2007 | 01:08 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Old Apr 9, 2007 | 01:46 AM
SEVNT6's Avatar
SEVNT6
You don't have to. Spring tension will keep the bolt, bushings and cups in place. I did mine a couple of years ago.........
Old Apr 9, 2007 | 01:48 AM
Twin_Turbo's Avatar
Twin_Turbo
they are probably peened over from the spring tension and the bolt riding against the ID. They are just a tight fit and pop out easily (at least on all the trailing arms I've seen) if they are not rusted in place.
Old Apr 9, 2007 | 03:00 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by Twin_Turbo
they are probably peened over from the spring tension and the bp;t riding against the ID. They are just a tight fit and pop out easily (at least on all the trailing arms I've seen) if they are not rusted in place.
I'll give that a shot. Thanks.
To Spring cushion cups
