Dropping the rear
Old Apr 8, 2007 | 10:35 PM
searay61's Avatar
searay61
Cruising
Default Dropping the rear
I wanted to drop the rear diff out of my 73. Everything else (t-arms etc) are out being redone and I figure, I've gone this far and might as well get everything else done.
My question, I loosed the two bolts that hold rear cross piece that the diff bolts to. Unbolted the driveshaft and loosened it from the front of the diff, and unbolted the bolt at the center (bottom) of the diff.
Should drop out right? It seems to be held where the bolts go into the frame...I can even take the bolts out and other than a 1/4 of an inch, it isn't moving.
I must be missing something and any help would be appreciated...
Thanks!
Old Apr 8, 2007 | 11:00 PM
chris73cpe's Avatar
chris73cpe
Those crossmember bushings are known to stick pretty good. Once you take those 2 bolts out, thread them back in 1/2" or so, then use a gear puller to pop it off. The jaws go on the crossmember and the center screw pushes on the bolt head. Once its free you can take the bolts back out and lower it down.
Old Apr 8, 2007 | 11:42 PM
strokervette's Avatar
strokervette
Use a jack to lower the diff and crossmember, it's a heavy sucker.
Old Apr 9, 2007 | 01:01 AM
wnjlt1's Avatar
wnjlt1
some have used the puller and others a long prybar. i used a ball joint tool (pickle fork) wedged between the frame and x-member, a couple of solid hits with a hammer on the fork to drop the diff. support the diff with a jack and the (2) backed off x-member bolts as suggested by chris73 & stroker . be careful not to hit the body. good luck!
Old Apr 9, 2007 | 08:17 PM
searay61's Avatar
searay61
Cruising
Default Thanks!
A little more brute force and out it came! Thanks! I thought it better to ask before pulling out the sledge hammer
John
To Dropping the rear
