Me's guys, articulated hinges...
Old Apr 10, 2007 | 10:05 PM
mrvette's Avatar
mrvette
Default Me's guys, articulated hinges...
need an up and over fresh air intake for a change....but need to
put a set of articulated hinges on the stockish hood arrangement....
to lift the front edge up and forward about 5-6 inches when opened, and close in normal position, and hold for say 150 mph or so....
rear latch is ok, I think,....but if needed changed, well ok...
so anyone have any ideas/pix/concepts/ drawings of just HOW this proposed hinge needs operate??
the front edge of hood need be forward and upward about 6" when opened....after that I hope to figger the other stuff....
Old Apr 10, 2007 | 10:12 PM
Durango_Boy's Avatar
Durango_Boy
I'm gonna be using a pair of Mitsubishi Eclipse trunk lid hinges for my hood hinges. They articulate several inches, and have a very similar over all closed thickness and a bolt pattern that's adaptable.
Old Apr 10, 2007 | 10:37 PM
mrvette's Avatar
mrvette
So you saying the would put the front of the hood UP and forward about 5" or so when raised?? interesting....
you actually have a pair?? from what series of car??
what years....they made that model for decades, I think..?
Old Apr 10, 2007 | 10:51 PM
Durango_Boy
A 1998 Mitsubishi Eclipse Convertible.
The vert is key since it has a flat trunk lid with a pair of articulating hinges with hydraulic struts. I found mine on Ebay but any local salvage yard should have them too.
Old Apr 11, 2007 | 12:20 AM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
C5 hinges are a good example of this. However, I think you will find that it is easier to make your own 4 bar lift (articulated hinge) than to adapt another hinge. I intend to put an air bridge in my car and have designed a lift out hinge but don't recommend it. A 4 bar hinged, lift out hood will also require a gas spring assist or it will lockup. This is difficult to explain but the gas spring has to almost go over center when the hood is closed so that the extension force of the spring is countered by the hinge itself instead of the hood (but still supply a small lifting force). All in all, probably not worth the time and expense.
Old Apr 15, 2007 | 12:55 PM
mrvette's Avatar
mrvette
OK, so how to do an up and over induction bridge?? I fail to see how to do it without radically changing the hood hinge arrangement....
i gotta look at the C5 hood hinges....
To Me's guys, articulated hinges...
