I'm getting ready to pull the body off of my 76'. I was planning on setting it down on some 4x4's on my flat bed trailer but I think this will limit my ability to get under it to work. Does anybody have a design for a good dolly that could be fabricated out of metal or wood? I've seen several in photo's here on the Forum and they all appear to be home made. I will probably dismantle and scrap it when I'm done so I don't want it too nice. I have a metal shop and MIG so I'm good to go there. I'm looking to buy a 4 pt. lift strap too but I'll post that in the WTB section later.
Most of the major Corvette vendors will carry the Noland Adams "Body Lift Workbook" and body lift video. The workbook contains instructions on building a body dolly - that is what I did. Money well spent and the workbook will save you time and may save you some costly errors.
Hey Pala,
You can get as involved as you want on a dolly of this type. My feeling was, as long as it properly supported the various mounting points on body, provided easy access to underside of body, and was cheap, that was how to go. I live in an area that abounds with manufacturing facilities, and I was looking for an oversize hardwood shipping pallet. In my case, it was an easy find. To the bottom of that I mounted 4 HD swivel casters. I then ran two stringers as long as the body, across the longest side of the pallet. Then it was just a matter of measuring where to place the cross braces in order to line up with the mounting points. It has been a great convenience to be able to easily roll the body around and in and out of my shop. If you want a couple pictures, send me an e-mail with your e-mail address for an attachment. Save your time and money for the car, you will need it! LOL
I was too cheap to buy the lift straps, so I picked up 2 nylon tow straps from Harbor Freight and tied them off to the right length. I then hooked one end to an opening in the inside front door pillar, and the other I bolted to the seat belt anchor on the rocker channel. I did that on opposide sides for each strap (driver's door pillar, passengers seat belt anchor, and vice versa), making an 'X' over the top of the body which I attached the winch to. It was much cheaper and seemd to work just as well.
I was a little concerned about this configuration "pinching" the windshield, but I left the T-tops in and even with my severely rotted out windshield frame, everything turned out fine.
Just a friendly addition to the above, be sure that you also support the nose of the car in some fashion during the lift. Once nose is unattached to frame supports, it becomes very fragile.Its own weight is capable of causing damage. I attached a couple ratchet straps to the front end structure and back to the hook before lifting up with an overhead crane. Ratcheted straps snug, not tight, and they provided good support during the lift. SLOOOOOW is the key!
I could talk all day ... but here are 1000 words for you.
...should give you some ideas.
I was going to have support in the front - decided a strap was better.
Also, I have a couple posts to hold the #4 mounts. Each 4x4 post can unbolt
from the frame with lag bolts. There is a 1/2" threaded rod in the top of each post,
so the body mounts can be firmly attached.
Thanks Duke,
Been looking for these links and you put all in one post!
Now they are on my hard drive.
This info sharing is what I love about this Forum!
Hey Dave,
Think my son and I might borrow that for the upcoming boxcar derby? Looks like you already have the perfect launch figured out!
TJMica...I assume that that question is directed at COINWASHER since he has such a sweet looking restoration. You may want to PM him your question if he doesn't see it here.
I like the NHvette style. I need to figure out the center to center dimensions but that shouldn't be too tough.
JustForFun....what's the ballpark cost for one of those and where does it attach (front clip on).
Coinwasher...That one is sweet but I would have to keep it around when I got done causing additional problems with wife!
Thanks!, Wife does want it gone because she thinks it may inspire me to do another one (smart woman)
Thanks Willem. I completely forgot about that. I also used a ratchet strap (and a helper holding it up).
Hey Rick....How long was your buddy able to hold up that body with his leg before fatigue set in??...Looks like fun. I see what you mean about the strap set up. Nice looking car. I'd like to see some pic's of your project.
What do you guys think about COINWASHERS LIzard Skin? Where did you get that stuff?? I personally like it and am thinking about using it on mine.
Glenn P
