71 stock wheel height
Old Apr 11, 2007 | 11:24 PM
CaptainHook's Avatar
CaptainHook
Default 71 stock wheel height
From the threads that I've read, it looks like the modern stock tire size for my 71 is 225/70R15. This results in 27.4" diameter. Others have said the stock wheel has 27" diameter which equates to 255/60R15. Is the stock wheel 27" or 27.4"? I'm trying to get a set of tires for my 17" rims and I want to keep the speedometer as accurate as possible. Thanks.
Old Apr 12, 2007 | 12:32 AM
SEVNT6's Avatar
SEVNT6
My TA's are 255/60 15......... And they're 27.1..............
Old Apr 12, 2007 | 09:32 PM
CaptainHook
So is the correct wheel 27" or 27.4"? Thanks.
Old Apr 12, 2007 | 09:38 PM
SEVNT6's Avatar
SEVNT6
If you're talking about outer diameter the Tire Rack shows mine at 27.1 inches.........
Old Apr 12, 2007 | 10:39 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
255/50X17. Same diameter as the stock 255/60X15.
Old Apr 12, 2007 | 10:49 PM
CaptainHook
But I read some posts stating the stock size is 225/70R15 which has an outside diameter of 27.4". If I go with 255/50R17, it will only give me 27". Will that make a big difference in the accuracy of the speedometer? Thanks.
Old Apr 12, 2007 | 11:12 PM
SEVNT6's Avatar
SEVNT6
In my case it sure didn't. My Vette came with G70-15s....or the same as a 225/70. And my speedo is right on the money................
Old Apr 12, 2007 | 11:29 PM
Sky65's Avatar
Sky65
According to Tire Rack says your 71 size should be 205/70 which are 27.1. Later years call for 225/70 or optional 255/60. What size are you running now. Compare that size to the others.
Old Apr 12, 2007 | 11:38 PM
CaptainHook
I have 255/60R15 right now.
Tire Rack says 205/75R15 and Discount Tire Direct says 225/70R15. I have no idea which has the correct size.
Old Apr 13, 2007 | 12:53 AM
early shark's Avatar
early shark
CaptainHook,
The original tire size for the 1971 Corvette, for that matter '68 thru '72 cars is 215 70x15. I am still running thee original tires on one of my '71's.
Old Apr 13, 2007 | 01:04 AM
SEVNT6's Avatar
SEVNT6
They would be about the same diameter. But no C3 ever came with 75 series tires.............
Did you mean 205/70?
Old Apr 13, 2007 | 12:30 PM
CaptainHook
Originally Posted by early shark
CaptainHook,
Thank. 215/70-15 is about 26.85" that is pretty close to 255/50-17.
Well, when I enter the info for my 71, Tire Rack said 205/75-15.
Old Apr 13, 2007 | 12:33 PM
wfo76's Avatar
wfo76
Original 68-72 F70-15 tires were 26.92"
P215/70R15 are the closest to the original size and appearance
Old Apr 13, 2007 | 01:16 PM
Sky65's Avatar
Sky65
=CaptainHook;1559798935]I have 255/60R15 right now.
Bottom line is if you are running 255/60X15 now, 255/50x17 will give them same speedo readings. They are the same diameter. Research complete.
Old Apr 13, 2007 | 05:02 PM
CaptainHook
Research complete! Bridgestone Potenza RE750 255/50ZR17. Thanks for all the help.
Old Apr 13, 2007 | 08:20 PM
Sky65's Avatar
Sky65
Looks like a good choice. Please post pics when you get them on. I am runnning 255/50X15 on the 65 now but I plan to go to 17s. That is the size I was considering as well. I would like to see what they look like on the rim. I want newer design tires but I don't want the tire sidewall too thin. I think this size will be perfect for me as well.
Old Apr 14, 2007 | 12:23 AM
CaptainHook
Will do. The rims should arrive next week. I have to shop around for a good price on the Bridgestone tires.
To 71 stock wheel height
