Head Gaskets For L98/ZZ4 Heads
Old Apr 12, 2007 | 02:05 PM
VictoriaVette's Avatar
VictoriaVette
Default Head Gaskets For L98/ZZ4 Heads
Any input on which head gaskets to use with the L98/ZZ4 heads?
Old Apr 12, 2007 | 02:50 PM
JIM's Avatar
JIM
I'm guessing these are aluminum. Use a Fel-Pro 1010 $37.95 ea from jegs or summit
Old Apr 12, 2007 | 03:16 PM
dgruenke's Avatar
dgruenke
I depends on the rest of your setup. Knowing your piston to deck clearance will help you get the correct quench. Knowing what pistons you are using will help you pick a head gasket that is the correct thickness for your compression ratio.
Old Apr 12, 2007 | 03:40 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
i just go to autozone and ask for an 87 vette head gasket.
To Head Gaskets For L98/ZZ4 Heads
