Not more alternator problems....
Old Apr 12, 2007 | 04:50 PM
craigbaker's Avatar
craigbaker
Default Not more alternator problems....
About 6 months ago I tried starting my '75 Vette and the battery had drained down. After a few tries (mostly recharging the battery) I replaced the alternator with a reconditioned unit from autozone. The car ran well for about a week, then the same thing happned - battery drained down to dead. Last week I recharged the battery, tightened the belt to the engine, and the same thing happened again ...I'm now starting to pull my hair out!
A friend suggested that I may have incorrectly installed the alternator, with the two push in plugs on the wrong way round. Should I try switching them over, or will (as I have done before) destroy the electrics?
Any advice or feedback please!
Old Apr 12, 2007 | 05:18 PM
Garys 68's Avatar
Garys 68
Not sue what would happen if the excitation circuit was always on. It might hurt the alternator.
But try this. With the key off, see if 1 of the 2 plug wires reads 12V on a voltmeter.
Then turn the key on. See if the other plug terminal now reads 12V.
If that's OK, I doubt someone snuck in one night and rewired your Vette.
I think more likely, you've got a current drain somewhere.
Shut everything off. Close the doors (interior light out). Disconnect the battery from the + terminal.
Get an ammeter and put the probes between the + terminal of the battery and the red cable.
If there's any amperage flowing, you've got a drain.
Then pull fuses until you find which circuit it is.
Then you have to track down the problem.
