vapor return line clogged
Old Apr 12, 2007 | 06:47 PM
ELDO GUY's Avatar
ELDO GUY
Default vapor return line clogged
Any body have any ideas on unplugging a vapor return line! I am running a electric fuel pump on my 69 vette with a ZZ4 and want to send the extra fuel back to the tank so my pump doesnt die. Ive heard that electric pumps like to "" run" . The line was capped up many years ago but now I want to use it but its clogged. I tried to roto rooter it with some wire but that didnt work. I could run a new line but that would be a real PIA. Thanks
Old Apr 12, 2007 | 07:44 PM
bluthundr's Avatar
bluthundr
A compressor, a piece of fuel line, and some really good hose clamps?
Old Apr 12, 2007 | 10:26 PM
KJL's Avatar
KJL
I thought that electric fuel pumps should be as close the the gas tank as possible. If so, could you not just tap into or run another line from there?
Why are you using an electric pump?
Old Apr 12, 2007 | 10:42 PM
wiseman79's Avatar
wiseman79
I don't believe you should use the vapor line as a return line. Someone else should chime in, I have just been told it's a no-no and don't know exactly why. You're connecting the return line to a regulator I assume?
Old Apr 13, 2007 | 07:53 AM
KJL's Avatar
KJL
I believe the line in question is a return line not a vapor line. I am also guessing he really means "return" line.
My recommendation would be to plumb the pump next to the tank and run a new return to the tank or splice into the existing line or just go with a mechanical pump with a regulator.
Why would you need a regulator on a return line??
It sounds like your return line is toast and running a new line is a PITA. You don't need an elecrtric pump for a carb application which I assume you are running.
Old Apr 13, 2007 | 01:18 PM
ELDO GUY's Avatar
ELDO GUY
Thanks for all the help! Ill try the compressed air and good hose clamp idea . The pump is located in the back . I put the electric pump in when I installed the zz4. I have headers and air and it gets a little tight on that side when you want to change the plugs . Not having the regular pump there gives me more room to work with.
Old Apr 13, 2007 | 02:50 PM
billsfan's Avatar
billsfan
If you're going to blow the air towards the fuel tank, remember to take off the fuel filler cap. A buddy of mine forgot to do that, and ended up with a 40 gallon fuel tank !!
To vapor return line clogged
