Lxx Questions?
Been shopping ebay, used engine/tranny packages out there from $1000 to $5000. What is the diff between LSx and LTx, 1, 2, 3....6?
Very confusing
TIA
LS1 5.7 L around 350 hp depending on what car, found in f bodys and
c5s
Ls6 is a hopped up LS1 differnt heads intake and cam I believe found in c5 Z06
LS2 6.0 found in c6s and gtos 400 hp
ls7 427 ci found in c6 z06 505 hp
try hanging around ls1tech.com
c5s
LSx motors have a completely new architecture then the previous chevy small block which dates back to 55 (original 265). All aluminum block and heads. Plastic intake. Much more fuel efficient then previous designs. Will not bolt in directly to older cars.
LS1- 346 cu.in. (5.7L) first found in 97 vette, 98 camaro/firebird. Anywhere from 320 to 350 hp depending on year and application. Highest horsepower in vettes. 345 hp from 97 to 2000. 350hp from 01 to 04.
LS6 - 346 cu.in (5.7L)found in 01-04 Z06. 385 hp in 01, 405 hp from 02-04. Revised heads with special valves (sodium filled) and higher lift cams, with a titanium exhaust.
LS2 - 6.0 L. New in 05 base vettes. 400 hp.
LS7 - 427 cu.in. 505 hp. 06 ZO6 to present Z06. Based on C5R & C6R race motors.
LTx motors. Different design of upper end, using same bottom end.
LT1 - first showed up in 92 vettes. 300 hp. Direct bolt in available to older vehicles.
LT4 - 96 Grandsport application. 330 hp. Different heads, intake and cam.
Hope this helps.
trw
The LS1 is getting more and more affordable, engine and trans incl. the wiring harniss and computer/AC compr/other accessories are about 2500-3000 for auto trans and 3000-4000 for a 6speed
Bone stock the LS1 is a great engine, aftermarket performance parts are very expensive compared to older 350s.... the coils for example are 500-600, intakes are $500, heads are $2000 and up....
According to LS1tech.com they changed the piston to wall clearance in late 1998 or 1999..... my '99 Z28 is fine....
So what does this have to do with Gen1, 2, etc...
I figured out Gen 1 is what I have now,as do most of the rest of you guys
Will the other gens, LS2, 7 ets bolt up to existing Tranny or does it have to be a 4L60? Wondering about the bolt patterns.
I may snag one of these motor/tranny packages for a later upgrade, plan on getting the car back on the road for a while before an engine project like this
Also don't forget about the cast iron version in the trucks and suv's.
If you want a half way affordable engine then get the LS1. It is very affordable if you're happy with the stock engine, complete take out engine/trans combos are on Fleebay all the time.
It is getting expensive if you want more power from your LS1. If you have a high milage LS1 that you want to bore and stroke (they make nice 383 kits for the LS1), upgrade the cam and the heads ... well, check out these prices yourself... that's about as expensive as a LS2, maybe more....
Left turn?
