Rear End Question
Old Apr 12, 2007 | 10:05 PM
Corvette Chris's Avatar
Corvette Chris
Default Rear End Question
Hi -- I generally hang out in the C4 section, but some shopping around has me asking this. I'm looking to potentially buy a drag car, and an early C3 seems like it's a strong candidate.
My question is how much power will a stock '68-'75 differential put up with at the drag strip? Anything that anyone has pertaining to this would be much appreciated.
Chris
Old Apr 12, 2007 | 11:00 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Chris
1) stick cars:
About 400 HP with slicks
Up to 600 HP with street tires (not Drag Radials)
2) automatic cars without transbrake:
About 550 - 600 HP with slicks
About the same with street tires..
with transbrake: 400 HP with slicks and 600 HP with street tires (as they will spin off the line with the transbrake)
As soon as you hook with transbrake or a hard stick shift launch, your rear won't live too long with 400+ HP.
Lucklily, there is a IRS setup that will hold up to over 1000 HP which is Tom's 12-bolt IRS which is almost bulletproof..
Old Apr 14, 2007 | 12:44 PM
Corvette Chris
Thanks Olivier! Car would definitely be an automatic because it would be a dedicated strip car. Definitely wouldn't run a transbrake before I went to a Tom's setup. Part of the reason I was hesitating to seriously consider a C3 was I didn't want to shell out the money right away for a Tom's setup. 550hp sounds like it's about where I'd want to be for a while.
I actually didn't realize the stock IRS would put up with that much power. Should've considered what the stock Big Blocks were putting out torque wise.
Old Apr 14, 2007 | 12:58 PM
GrandSportC3
It also depends on how old your posi is.. If the rear end components were rebuilt recently, I'd think that you can get 100 - 200 passes out of a stock rear.. However, if you run stock half shafts, it's a good idea to run half shaft loops..
Old Apr 14, 2007 | 01:21 PM
GTR1999's Avatar
GTR1999
Good point- depending on the year you'll have 10-18 or 10-17's. The 17's are much better but the stock rebuilds are sloppy. If you're going to push it hard you need heat treated 17's, solid clutches, polished case, HD cross shaft, and ARP RG bolts. Add a steel cap and solid sleeve.
Old Apr 14, 2007 | 11:03 PM
GrandSportC3
I had good results with the Auburn Posi. It's a non-rebuildable unit but tends to crack less than the stock Eaton unit. I ran a Auburn posi for a while with 365 RWHP and a 5-speed.. Ran in the mid 11's and that posi held up for a while..
Old Apr 15, 2007 | 09:12 AM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
Chris
Power doesn't break parts...traction does!!!!!
To Rear End Question
