Turned the corner - radiator installed!
Old Apr 12, 2007 | 10:39 PM
alanbl's Avatar
alanbl
Default Turned the corner - radiator installed!
Finally, the first new component in my "winter" project is installed. Put in the Dewitt radiator with electric fans tonight. Feels good to start putting this guy together.
Old Apr 12, 2007 | 10:47 PM
SILVERSIXX's Avatar
SILVERSIXX
Good job Man! Feels good when things are finally done.
Old Apr 13, 2007 | 09:15 AM
Rickman's Avatar
Rickman
Alan,
Great pic of new Rad. I've been thinking of adding a Dewitt to my 72 BB.
Good luck w the rest of the project. Love the Steel Cities Gray.
Rickman
Old Apr 13, 2007 | 09:47 AM
BerniesVette's Avatar
BerniesVette
I can't believe the difference the DeWitt rad. made in my 92! You will love it! Make sure you install new seals on the sides and top of the rad. to force air thru it at highway speeds.
Bernie
Old Apr 13, 2007 | 10:30 AM
alanbl's Avatar
alanbl
Originally Posted by Rickman
Alan,
Rickman
The radiator does fit perfectly as advertised ------ once I figured out the secret. When we first tried to install it, the fan would not clear the left A-arm. No instructions were included - I suppose Dewitt assumes a much higher degree of competentcy than I have! A call to Tom Dewitt solved everything. As I suspected but wanted to confirm, the fan assembly comes off with 6 self-tapping screws and then can be re-positioned to fit correctly. Once I did this, my friend and I had no problem dropping it in.
To Turned the corner - radiator installed!
