oil pressure sensor orientation
Old Apr 14, 2007 | 02:30 PM
BigJim13 JR.'s Avatar
BigJim13 JR.
Default oil pressure sensor orientation
HI
i want to move my oil pressure sensor down to the spot above the oil filter on the block. however this spot would orient it horizontally. can an oil pressure sensor be used horizontally or do i need to get a elbow to move it down there.
THANKS
Old Apr 14, 2007 | 03:43 PM
SEVNT6's Avatar
SEVNT6
Mine came from the factory mounted horizontal above the filter. It has a brass fitting that goes between the sender & block that you might need...........
Old Apr 14, 2007 | 06:06 PM
Durango_Boy's Avatar
Durango_Boy
It's fine in either location or configuration.
Old Apr 14, 2007 | 09:33 PM
Big2Bird's Avatar
Big2Bird
Yep
To oil pressure sensor orientation
